Question about Maytag 24 in. MDBH950AW Built-in Dishwasher
After a wash, my Quiet Series 100 Maytag washer has fine grit all over the inside of dishes. Is there a filter somewhere I should be cleaning?
    Brigadier General:
  • 4,088 Answers
Try changing the brand and type of detergent that you are using. Some seem to work better under hard water conditions. Hope this helps.
Posted on May 07, 2010
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Maytag Quiet Series 400 and I can't get it to run on Normal,lite or other. I get a code 82 that appears. What does this mean?
My Maytag quiet 400 series is doing the same thing-buttons aren't responding or working. And now a second problem...it has become very loud and sounds like it is chewing up all the dishes.
PattyQ
Jan 10, 2010 | Maytag Dishwashers
Doesn't get dishes clean soap doesn't even rinse off
use less soap and you have to pre wash your dishes it is a washer not a food grinder
Dec 06, 2009 | Dishwashers
Maytag quiet series 200 Legacy not cleaning
under the unit where the water line connects,this is where the filters are.disconnect the water line take the fitting off that the line was hooked to,screen is there under fitting.
Jul 15, 2009 | Bosch 24 in. SGS43C12 Classixx...
Maytag Quiet Series 100, Model # MDB5600AWS, built in dishwasher. Does not get the dishes clean, dishes stay dirty after multiple cycles of washing. Please help!
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Jun 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Maytag 24 in. MDBH950AW Built-in Dishwasher Logo
1,356 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
