Question about Maytag EPICz 3.7 cu. ft. Washer
Water has leaked from the bottom of the Washer and now it is flashing F-30?
  • 11,896 Answers
F30 - DISPENSER SYSTEM ERROR
When the dispenser motor cannot be driven to its proper position.
Possible Causes/Procedure
1.Unplug washer or disconnect power.
2.Check mechanical linkage from dispenser motor to the top of the
dispenser.
3.Check wire harness connections to the dispenser motor and Central
Control Unit (CCU).
4.Check dispenser motor for powered rotations.
Posted on May 07, 2010
Water leaks from bottom of washer a day after I've done laundry
My guess is you have a slow leak in the inlet. Probably somewhere after the valve. Try turning the valves off between washes. If that fixes it you know it's an inlet leak. There is usually a pair rubber hoses (same connectors as a garden hose) connecting the washer to the inlet valves. In order of ease/price of fixing:
  • one of the gaskets in the hoses is cracked ($0.05)
  • one of the hoses has a crack or isn't sealing properly ($10)
  • the valve outside the washer is leaking ($15 if you DIY, $150 for plumber)
  • The connector or valve in the washer is leaking ($20-$30 if you DIY, $$$ if you pay a repairman, $0 if it's under warranty)
Mar 27, 2014 | Washing Machines
My washer is flashing f33 what do i do
F33 Leak. If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. Check your inlet valves for block, where the water comes to machine OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press 'pause' and 'cancel' twice to clear the display. Mains off the wall.
1. Check for crack or holes in the washer tub and pressure switch hose, which runs from the
bottom to the pressure switch.
2. Replace components if necessary.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
ADP5550 DISHWASHER RINSING LIGHT ON, START LIGHT FLASHING TWICE, BUT STUCK WILL NOT PROCEED WITH THE WASH. I HAVE PRESSED THE START BUTTON FOR 10 SECS, 30 SECS BUT THE ONLY RESPONSE IS THE PUMP ONLY RUNS...
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
Apr 13, 2010 | Whirlpool 24 in. DU920PW Built-In...
The washer leaked water out the bottom after the wash was finished. It took 4-5 towels to soak up the water. What is wrong with the washer?
you will need to open the machine (front panel - most times its 2 screws on the bottom)
and turn the machine on & look with a flash light where the water come from...is it busted pip , or pump is bad...
good luck
911servicetoday . com
Oct 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water leaking from front of washer
good luck
911servicetoday .com
Sep 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
Sep 19, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
F33 displayed in whirlpool duetsport frontloading washer
Press ‘pause’ and ‘cancel’ twice to clear the display. Mains off the wall.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag EPICz 3.7 cu. ft. Washer Logo
134 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
