Question about Karcher 2500 PSI Pressure Washer
Engine starts easy. engine revs up and down but does not maintain a constant. Preasure tries to come up and then quits. the governor eeps moving back and forth. I have cleaned everything including the unloader. I used lithium grease on the o rings and still it does the same. Could this be caused by bad gas, even though it starts and runs very easy
  • 2 more comments
  • t_covert May 07, 2010
    I've already checked and cleaned all conections. Water supply is very strong. It just seems like it can't get the motor reved enough to pump up the preasure.
    The problem happened last summer when I ran out of gas and put new gas into it. It started and the presure was good for a few moments and then the preasure just died down.
    Where is the preasure regulator located?
    I have taken the triger wand off and ran the unit. It did not put out any more preasure.
    I read about pouring oil into the water inlet valve and taping with a hammer. Would I tap on the place where the unloader houseing is?
    This unit has not been run but a few hours and I've kept it in my climate controled garage during the winter.
    this is low preasure. I've done everything that the manual has suggested. nothing works. I read on your site that the water inlet could have some motor oil poured in it and let it sit over night. Would this help loosen up the valves?
  • 3,740 Answers
Hi And welcome to FixYa. I am Kelly
I doubt that it is caused by bad gas.
-It can be caused by a dirty float bowl nut or a restricted orifice in the bottom of the carburetor venturi.
- Also a broken or very worn governor spring can cause it to hunt.
-On a vertical Honda Engine the rubber hoses being cracked can cause this also.
- A worn or missing butterfly spring can cause this.
Is this a Briggs and Stratton engine or a Honda GX160? Also Horizontal or vertical? That information is important and needed to offer your the correct response. Complete Engine Model number is needed for parts reference also.
I will respond as soon as I can once I have that Engine Model Number information.
Thanks,
Kelly
Posted on May 08, 2010
  • 1 more comment
  • Kelly
    Kelly May 08, 2010
    Hi, I am the person that said oil through the water inlet will help with pressure related problems. The unloader is on the power head before the pressure hose feed line. What ever you do, don't hit the power head with a hammer. USE block of wood and hit the wood! If it persists the only other option is disassemble and clean the unloader. There are several small parts so be real careful if you get to the point of working on the pump. It can turn into a $389.00 plus shipping mistake.
    One other thing to do is to rapidly fan the wand control on and off like 30 times or more at 0.5 second intervals to force the unloader to work more often AFTER you put oil through the pump.
    Kelly
  • Kelly
    Kelly May 08, 2010
    Download this parts manual The unloader / thermal valve that is supposed to reset is Item(s) 9 {Valve 60 GND} and 12 {Spill Valve} of detail A on page 11. The spring, seals and housing need a good thorough cleaning to get high pressure. If the seals are damaged they will have to be replaced.
    Kelly
  • Kelly
    Kelly May 08, 2010
    See the Karcher link here and watch the video
    http://www.karcherresidential.com/help/i...
    Please go to: http://www.karcherresidential.com/en/vid... and click on the "Troubleshooting: Inconsistent Pressure"
    That is about all I can do from here. Lets it works for you.
    Kelly
    Brigadier General:
  • 4,090 Answers
Are we talking compression in the engine or water pressure here?
The pressure of the water that the motor pumps is controlled by a pressure valve and seals, some of which it sound like you have found. But overall it is the pressure valve which maintains the volume and pressure of delivery of the water.
I had my own done recently and the cost was $150.00to replace the valve and service the unit.
Hope that is what you were asking
Cheers
Posted on May 07, 2010
  • dennis bullard May 08, 2010
    I found this recommendation frrom another entry that describes the use of oild and where to hit it
    These pumps are notorious for seasonal problems.
    Tip the unit to the
    point you can pour engine oil into the water inlet connection. What
    your attempting to do is free up the ball seats in the pump. They get
    corroded when they sit and lock in place. Adding the oil or a vast
    amount of WD 40 to the water inlet often does the trick for loosening up
    the seat balls and springs.
    After you add the oil (3 - 4 ounces) or
    WD 40 to the water inlet line just slowly pull the engine through with
    the ignition switch off. As the water inlet cavitates add more oil.
    Let
    it sit over night and then take a block of wood and a hammer and tap on
    the power head. Don't over do it and do it in such a manner your not
    going to shear off any bolts or break anything. But... be serious with
    the hammer and block of wood.
    Then connect inlet water hose, the
    pressure hose and test the unit. You may want to purge the oil lubricant
    into a bucket before you start the engine.
    Give it a try and see what happens.
    nettiser
    Guru:
  • 1,051 Answers
If the engine is running you can rule out bad gas. Check the couplings and the pressure reguator to ensure a tight seal.
  • Bob Korsu
    Bob Korsu May 07, 2010
    Sorry, I didn't take a long look at at the Karcher model you have. Unfortunately thr pressure is regulated in the 1st stage (the main unit) then distributed in the form factor you need in the second stage (the handle/trigger mechanism). If you can remove the entire trigger mechanism and the unit runs OK, the problem is a defective valve in the trigger housing.
    Sorry to be putting you through all this.
    radar
  • Bob Korsu
    Bob Korsu May 09, 2010
    Another consideration is the motor is in need of a tuneing to get it to run at optimum speed. Try adjusting the choke (small lever, usually just in front if engine) to increase gas/air mix. When moving the chock listen for the engine to change speed. At it's fastest is near best.
Governor linkage
There are two main types of governor and the centrifugal type tends to be reserved for heavier stationary type engines. Most portable lightweight appliances use a vane-type governor where a vane is placed adjacent to the cooling fan so the faster the engine revs the more air is moved and the more the vane will move against it's restraining spring.
There is a spring biasing the throttle to fully open and this spring is connected to the throttle or speed control lever.
There is a link connecting the throttle to the vane. After starting the engine speed will rise until the governor vane moves under the rush of cooling air forcing the throttle butterfly to close against the spring pressure until the vane pressure and the spring pressure are equal and therefore a constant engine speed is achieved.
Moving the speed control lever to increase speed tensions the spring and opens the butterfly causing the engine speed to rise until the vane force again equals the spring pressure.
This is a fairly basic but very common type. There are variations using two or three springs but the principle remains the same.
Aug 10, 2016 | Garden
Champion lawn mower Starts but revs flat out
your governor spring may be in the wrong hole. start engine and move governor arm either way. one way should slow engine down. if this is the case then move your spring to a location that will hold arm in that spot. if this is not the case then you may have a broken or damaged flyweight on your governor inside engine
Oct 17, 2014 | Garden
I have a Husqvarna GT 2548 with a 25 hp Kohler eng. Engine idles fine and drives fine until I engage blades , then it bogs down. It is really bad if I am moving up an incline. I checked the blades and...
The governor regulates the engine speed and when a load is applied that would slow the engine it is the governor's job to open the throttle to maintain the speed. It also limits the maximum engine speed to a safe level. As a user of the machine you should have formed an idea about whether the governor is working correctly.
If the governor linkage moves freely against the spring(s) and the maximum revs of the engine are about right no adjustment should be attempted and the fault probably lies elsewhere, most likely fuel starvation though bad ignition or valve timing, tight valve clearances or partially blocked exhaust can affect power output.
A back-to-basics approach is usually the best if the problem has built gradually but if it happened suddenly I suggest you begin by thoroughly cleaning the carb.
Aug 05, 2017 | Husqvarna Garden
Idle problem
There is an arm that runs from the governor arm to the carb. There should be a long spring on this to even out the revs. If that has come off it can cause similar problems. If you have checked/reset the governor arm on the pinion that comes out of the crank housing and the spring is in place I would think the only other problem is the actuator that operates the governor arm pinion internally. It is a strip down job to check it, but there is a (plastic?) cog that runs of a gear on the side of the crank shaft. This has a weighted pusher that moves with engine speed to move the governor arm. I have seen a couple of engines where there is wear and the weights have popped over the 'top hat' pusher stopping it moving freely and causing full revs. If you're not confident in stripping the crank casing down (you can leave the piston and crank in place to check the governor mechanism) then you should definately take it to a dealer or experienced technician.http://www.honda-engines-eu.com/engines/PartSelection.jsp?model=GX390K1&type=BJ&npl=10ZF601%20&lang=EN
Position 9 is the governor assembly.
Jan 11, 2012 | Garden
Unstable frequency
check your governor and linkage for build up of dirt and grime. You should be able to move the governor by hand, with some resistance from the springs. The governor arm should not rotate about the shaft protruding from the engine.
If governor seems to be in order, and engine cannot maintain RPM that it needs to (hunts), look towards the carburetor being fouled (clean out best you can, but don't soak since it is an EPA carburetor), air cleaner dirty (replace even if looks good), or loss of compression (check with compression tester, should be around 90 psi or better with engine warm).
Jun 08, 2010 | Coleman Powermate Premium Plus 6250W...
10 hp briggs runs at high speed, govenor don't seem to be working
One possible cause for this problem is debris,sticking,or frozen linkage between the governor and the throttle butterfly. Depending on the make and model of your engine it will either be a mechanical governor that has a arm that goes down into the case or a air vane governor that is behind the recoil shroud of the engine. Move all the linkage that connects between the governor and throttle and speed lever to make sure it doesn't bind or sticks. If it does pray a little silicone or wd 40 spray on it to help reduce friction. Also on air vane governors they can become stuck from debris that inhibits it from moving make sure there is nothing in the way of the governor. If all of the linkage is working properly and you still have the issue try adjusting the the fuel mix screws and the high rev. settings on the throttle lever (if equip.).
Jan 29, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Engine revs wide open when starting
Check to see if the throttle shaft on the carburetor is actually moving (with engine off) Does it slow down when you move the throttle control on the dash?
Start it up and try moving the linkage on the governor shaft, if there is little or no resistance but the engine slows when you move it, most likely you have a broken governor gear inside the engine. Another possibility is that the screws that hold the throttle plate to the shaft have come loose and the plate is jammed in the throat of the carburetor
Sep 14, 2009 | Garden
Coleman Powermate generator will not start.
Changed plug since last year?Choke adjustment? try premium gas?
Aug 13, 2009 | Electrical Supplies
I have a 1998 Jeep Cherokee with a 4.0L engine. The oil pressure gauge usually stays around 40 on the highway but when I come to a stop it drops down to 10. Is this normal or is my oil pump getting ready...
No this is normal. As an engine wears then oil preasure will be less this is not due to a weak oil pump but wear in crank shaft bearing's. When an engine is new and bearings are tight then oil preasure wont fall a lot from reved up to idle as the engine wear's oil escapes quicker from the crank shaft bearings. Reved up oil preasure increases idle it drops off. If the oil light stays out then their is enough preasure to lubricate the engine. In fact in an older engine high oil preasure is a worse complaint as this means the oil system is clogging. All is ok with your pump. If the oil preasure is moving up and down at constant rev.'s then the oil pump is faulty. Hope this put's your mind to rest.
Aug 11, 2009 | 1998 Jeep Cherokee
Engine won't maintain constant rpm
Hello There
Try cleaning or replacing the spark olug.
Hope this helps.
Many Thanks
May 22, 2009 | Coleman Powermate Premium Plus 6250W...
Karcher 2500 PSI Pressure Washer Logo
176 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
