Question about Canon PowerShot SD1000 Digital Camera
Card Locked message is on my camera screen and I have not found how to remove it.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
    An expert that gotĀ 20 achievements.
  • Canon Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on May 07, 2010
What you need to do is, find your memory card that should be in your camera. If you look carefully, along one of the edges of your memory card (commonly found on left edge), there should be a mini switch that slides up and down. Try to slide it the other direction which may unlock the data in your memory card. Most memory cards should have the switch slided up to activate that data is unlocked and free to use.
Posted on May 16, 2010
4 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: camera will not shoot
Did you try setting the slide switch on the side of the memory card? And if that doesn't work, did you try a different memory card?
Posted on Jan 21, 2008
t00nz
  • 4738 Answers
SOURCE: Loaded new memory card, and screen reads memory
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Posted on Dec 25, 2009
  • 59 Answers
SOURCE: My camera suddenly had the message "card locked!".
The problem is your memory card. We can't fix it. The best solution is to buy a new one. Remember if you got an message error like that it shows that your memory card is going to be a dead set. don't use it again it may working for sometime's but suddenly its error appear again and picture got lost. USED A NEW ONE.
Posted on May 05, 2011
I have a locked disc message across my view screen. Camera will not work. carol
If that camera uses an SD card, there is a little switch tab on it, this prevents data from being written to the card, check the card switch.
Nov 03, 2016 | Cameras
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
I cannot take any pictures or delete them as i am getting a message on screen that says 'card locked' How can i remove this message?
Hi, removed the memory card and look you may find a button on the card and moved to the unlock position that is the write protect switch and it should work...if not thats is something in the setting menu...
hope that will help you
regards Alan
Oct 22, 2010 | Samsung NV8 Digital Camera
I place the card in the camera, close the door and turn the camera on. The message "card locked" appears on the screen and I cannot use the camera at all. How do I unlock the card?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Oct 19, 2010 | Cameras
The card is locked appears on screen when SD card is inserted
Is it possible for you to use some tweezers and adjust the very small lever inside the camera's card bay? It may be stuck thus telling the camera the card is locked.
Aug 27, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
