Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Need repair manual for briggs 190412-6111-01 engine
Need a repair manual .pdf for a Briggs and Stratton Model 311707 Type 0132-E1 engine
H.A., Check the attached links,instruction and guides for Briggs and Stratton, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My 311707 0132 E1 Model Overview from PartSelect com
http://www.smallenginesuppliers.com/html/engine-specs/briggs_vertical_shaft_engines/276781SingleCylinderOHV.pdf FAQ Small Engine Specifications Briggs Stratton Specs
Briggs Stratton Small Engine Specifications
Jul 01, 2016 | Measuring Tools & Sensors
NEED REPAIR MANNUAL FOR BRIGGS AND STRATTON REPAIR MANNUAL
Hi - you can download manuals for all current and the vast majority of older engines direct from the Briggs website (owner/maintenance manuals and Illustrated Parts Lists) . You can also buy proper 'strip down and repair' manuals from Amazon among other places. Note - these are official publications and it's unlikely you will find them for free (they're illegal if you do!).
Aug 06, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I need a free copy (download) of a workshop manual to suit a Briggs and Stratten 375 petrol engine?
Workshop (repair) manuals are available for ALL of the Briggs and Stratton engines. They usually cost money though. The free downloads are only for the owner's manuals. You can do a search for Briggs engine repair manuals. There are many, many of them available.
May 22, 2011 | Garden
Need repair manual for briggs and stratton 4.5 hp on bolen lawn mower model 11a-414e765
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
May 10, 2011 | Briggs & Stratton Briggs Stratton...
Want a repair manual for a 17 hp briggs & stratton engine
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Oct 01, 2009 | Garden
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
282 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
