Question about Lexmark X7675 Wireless All-in-One Printer
My Lexmark 7675 only copies part of the page. It doesn't matter how I re-size the image it will only copy the upper middle of the page.
  • Official Brand Answer
  • 3,344 Answers
I'd like you to try these steps. Unplug the power supply(black box behind the printer where the power cord is attached) from the printer. Hold down Start and Cancel buttons at the same time while plugging back in the power supply. Continue holding down the two buttons firmly until Language Selection comes up on the display. Release the two buttons. Set the printer like your setting it up for the first time (set the time and date, etc.). After getting Initial Setup Complete on the display, try making a copy again. If problem persists, then it's probably hardware issue in the printer. If this is the case, I suggest you contact Lexmark Technical Support for further assistance. Thanks.
Posted on May 07, 2010
My Lexmark all in one won't scan the entire document. No matter what size setting I put it on (I get the 'most' scanned on Automatic, but it is still less than half the page.)
Do you get the same result when making a copy using the Copy button on your printer operator panel? Try to remove the power adapter from the printer.
Wait at least 10 seconds before replugging the power adapter. This will give enough time for the printer to reset itself. When the printer turns on, reinsert the cartridges. Load some paper and try to make a copy or scan again.
May 05, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
How we make photocopy in a x1190
You can photocopy on this printer by following these steps:
Note: You can make a quick color or black and white copy.
Press Color Copy or Black Copy on the control panel.
To make black and white, gray, or color copies:
1 Open the top cover of the All-In-One.
2 Place the item you want to copy face down on the glass. Make sure
the upper left corner of the front of the item aligns with the arrow.
3 Close the top cover.
4 Open the Lexmark All-In-One Center (see page 3).
The All-In-One Main Page displays.
5 Click See More Copy Settings to review and change the copy
settings.
6 Select your copy settings.
Note: You may want to reduce or enlarge the image.
7 Click Copy Now.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Lexmark X1190 All-In-One InkJet Printer
How do I access the menu/control panel?
MFP and scanner settings can be changed several ways: through the MFP control panel, the software application in use,
the print driver, MarkVision™ Professional, or the Web pages. Settings changed from the application or print driver apply
only to the job being sent to the MFP.
Changes made to print, fax, copy, and e-mail settings from an application override changes made from the control panel.
If a setting cannot be changed from the application, use the MFP control panel, MarkVision Professional, or the Web pages.
Changing a setting from the MFP control panel, MarkVision Professional, or the Web pages makes that setting the user
default.
Menus (A key is shown on the button.) Touch to access the menus. These menus are only
available when the MFP is in the Ready state.
The Menus button is on a gray bar called the navigation
bar. The bar contains other buttons described as follows.
Understanding the copy screens and options
Copy From:
Opens a screen where you can enter the size of the documents you are going to copy.
Touching any of the paper size icons on the follow-on screen will make that your selection and return you to the
Copy Options Screen.
When Original Size is set to Mixed Sizes, you can scan different size original documents (letter and legal size
pages). They will be scaled automatically to fit the selected output media size.
Copy To: Opens a screen where you can enter the size and type of paper on which your copies will be printed.
If the size settings for Copy From and Copy To are different, the MFP will automatically adjust the Scale setting to
accommodate the difference.
If you have a special type or size of paper that you'd like to copy onto that is not normally in the MFP paper trays,
you can select MP Feeder, and manually send the type of paper you want through the MP feeder.
When using Auto Match, the MFP will match the size of the original document as specified in the Copy From box.
If a matching paper size is not loaded in one of the paper trays, the MFP will scale the copy to fit loaded media.
Scale: Creates an image from your copy that is proportionally scaled anywhere between 25% and 400%. Scale can also be
set for you automatically.
When you want to copy from one size of paper to another, such as legal size to letter size, setting your Copy From
and Copy To paper sizes will automatically change the scale to keep all the original document information on your
copy.
Touching the arrow to the left lowers the value by 1%; touching the arrow to the right increases the value by 1%.
Holding your finger on an arrow makes a continuous increment.
Holding your finger on an arrow for two seconds causes the pace of the change to accelerate.
************************Darkness: Adjusts how light or dark your copies will turn out in relation to the original document.****************** here is the link to the full pdf manual for your unit: http://www.lexmark.com/publications/pdfs/2007/x644e/en/ug.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1270220491739&answerid=16777216&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2F2007%2Fx644e%2Fen%2Fug.pdf&productCode=&highlightinfo=106955230,537,548
Apr 02, 2010 | Lexmark X 646e MFP - multifunction ( B/W )...
Can an all-in-one printer be used without a computer?
yes, you can make a copy and fax but you can,t scan any document ....
for fax you have to connect the phone cable to the printer and for copy the document press the copy button and put the document in the upper paper feeder
Dec 28, 2009 | Lexmark X2550 All-In-One Printer
Cant copy A4 size
give print...select printer ....goto properties of the printer in the same dielog box.....then ....more page layout options .....there you can change the page scaling
Oct 05, 2009 | Lexmark X4650 InkJet Printer
How can I scan without problems on a lexmark x3470 all in one
Hi..
To scan a document using the Lexmark Imaging Studio on ur Lexmark X3470, follow the steps given below:
1. Go to "Start," "All Programs," Lexmark X3400 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
To make a standalone copy:
1. Load the paper.
2. Select the "Copy quality" you want.
3. Open the top cover of the All-In-One.
4. Place the item you want to copy face down on the scanner glass. Make sure the upper left corner of the front of the item aligns with the arrow on the right of the All-In-One.
5. Close the top cover.
6. Change copy settings as needed.
Press "Black Copy" or "Color Copy."
hope this was helpful...
Apr 24, 2009 | Lexmark X3470 All-In-One InkJet Printer
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Problem with using the printer copy feature
Please make sure you are positioning the page to be copied on the scanner bed correctly. There is usually one corner of the scanner where you should place the page.
Most scanners mark the "home" corner with either some obvious tic marks or even painted arrows.
Mar 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
Need to know how to use the scanner on a lexmark 6500
You can change the resolution (dpi) of an image or of the copies you're making from the 6570. Here's instructions on how to do both:
Change the resolution of copies:
1. From the operator panel of the printer, press Copy Mode.
2. Press the menu button.
3. Press the arrow buttons until the Quality option appears.
4. Press the check to select Quality.
5. Press the arrows until the quality you want appears (you can't choose a specific dpi here, but you can adjust the quality).
6. Press the check to select it.
7. Press Start Color or Start Black.
Change the Resolution of an image:
1. Open Productivity Studio.
2. Click File > Open and select the image you want to edit.
3. Click Advanced.
4. Click Image Resolution/Size.
5. Select Photo Size to select from a list of defined photo sizes, or click Custom Size to enter a different size.
6. If you select Custom Size, type the width and height you want to use for the custom size.
Jan 19, 2009 | Lexmark X6570 InkJet Printer
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Jul 12, 2008 | Office Equipment & Supplies
Lexmark X7675 Wireless All-in-One Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
