Question about Dryers
Maytag Bravos Steam dryer is flashing "AF" and clothes do not dry well.
    President:
  • 949 Answers
AF stands for poor air flow, here is what Maytag says about it following that will be my comments.
AF flashes if low inlet air flow is detected
at install.
Check to see if the vent run from the
dryer to the wall is crushed.
Air flow restrictions are usually found behind the dryer in the vent hose. You can take if off and clean out the hose from the dryer to the wall. Go outside and check where the dryer vent exhausts from the house, this could be blocked with lint. The dryer will not work properly without the right air flow, if the vent behind the dryer is clear and the opening at the outside of the home is clear the problem may be in the venting in the walls, between the two
Let me know if you have questions.
Posted on May 07, 2010
Kenmore oasis dryer
Them oasis dryers and maytag bravos dryers all have a design blower with a small belt that tends to come off. Check this out
56bfeca7-24ae-4c69-8f40-12e24b03f02b.jpg ec813e4d-c675-4f0a-afde-b9585e5124aa.jpg
Oct 13, 2014 | Kenmore Dryers
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
My maytag bravos dryer is not drying?
sounds like your heating element is going bad
Jun 17, 2012 | Maytag Dryers
No matter what settin the dryer is on my clothes will only get a little warm, but won't dry. It won't heat up as usual.Had a load in there for a few hours yesterday. They are still damp. When dry clothes...
You vent could be the problem. Snow blocking the vent can cause the dryer heat to shut down rapidly. Make sure your vent is open to the outside. Get some windex and clean them moisture sensors inside the machine. If a film developes on them then moisture cannot be detected by the control. It might think the clothes are dry and shut her down. Maytag Bravos Dryer service Manual
Feb 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Apr 23, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
AF light comes on
It means "Air Flow" there is lint caught in your vents. You will need to vaccum them out.
Mar 25, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
