Question about HP DeskJet F380 All-In-One Printer
HP DeskJet F380 won't copy
Will print, but won't copy. Tried disconnecting USB & then reconnecting, but didn't help.
  • 2 more comments
  • Anonymous Apr 23, 2008
    hp f380 won't scan
  • bettyrounds Jun 03, 2008
    DISCONNECT USB AND RECONNECTING CLICKED ENTER
  • Anonymous Jun 17, 2008
    I did connect printer to new pc but the page where it says scan and copy to printer does not show on my pc - can you help
  • dadadit Jul 15, 2008
    wrote document on microsoft word processor and asked for the printer to print
    It accepted blank sheet and returned it blank .took a second sheet and sounded as if something was printinf but it came our blank as well
    Novelist:
    Scholar:
  • 125 Answers
If you can't get it to scan an image then you might have to have it brought to a repair center. How often do you use the copy function? Scanning function?
Posted on Apr 23, 2008
Hp 380 allinone won't print or copy but will print something i scanned in
it is better dont purchase HP series.. its all waste... they are simply selleing by advt. No customer service. Useless....
Dec 14, 2011 | HP DeskJet F380 All-In-One Printer
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
I tried to run the HP Deskjet F-380 Installation CD on Windows 7 64 bit and I get the message that my system won't support it.Windows Vista didn't have any problems so what gives?
Instead of using the CD:
1. Unplug the printer from the computer.
2. Download the driver at the by clicking here. Let the program run and finish installation.
3. Reconnect the printer and Windows will auto detect the printer.
Jun 15, 2011 | HP DeskJet F380 All-In-One Printer
Ink cartridge light of mt HP Deskjet F380 All-in-One is blinking and an E appears, have tried replacing cartridges and everything, but no result whatsoever.
Hi
Please try this solution
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
Apr 09, 2011 | HP DeskJet F380 All-In-One Printer
My HP Deskjet F380 has the latest printing software installed; it spools and is attached to my laptop in the correct USB port; but it doesn't print. The message is "no connection." It printed...
Verify that the USB connection is fully inserted in the back of the printer itself. If all is well there, try to think if you've run any updates on your laptop recently, or installed any new software that could be conflicting. If yes, try removing the new software or recent updates, and try a test print. If this still does not work, try disconnecting the printer, powering down your machine, starting it back up and then reconnecting the printer to the USB port. Sometimes you have have a glitch in the USB port that causes your computer to stop recognizing a device seemingly out of nowhere. If none of the above seems to help, it might be as simple as a USB cable that's become faulty. Hope this helps!
Nov 19, 2010 | HP DeskJet F380 All-In-One Printer
I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet f380 print and scan function copys with a wide black
clean the print heads and run clean cartridge utility from printer properties window.after that
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.
Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
Prin queue problem
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Aug 31, 2008 | HP DeskJet F380 All-In-One Printer
Won't work
Leave the printer on but unplug the power cord and USB cable. Wait 30 seconds and plug printer back in. Once it has finished coming on and initializing reconnect the USB cable. Try to print - up and working?
Assuming that the issue is software first uninstall the current drivers and then you can download and reinstall from the hp website. Just select your OS and then pick the most recent full feature software and drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 06, 2008 | HP DeskJet F380 All-In-One Printer
Printing problem
Have you tried changing the cartridge or refilling the black and colored ink cartridges?
Jul 25, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
547 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
