How to scan a docement to jph - Computers & Internet
  • 51 Answers
You can find that in your settings in the software for your scanner.
You can find the software for your scanner in Start Then Programs or All Programs
Posted on May 08, 2010
Loading paper
In this particular case you want to use the "By-Pass Feeder". Open the first door where the toner cartridge goes. There are two sliders narrow them down to the width of the index cards with a few in-between them. Once you do this it should auto select them when you print as long as you tell the docement in the properties that it should select the by pass feeder. It must be selected in the document properties or you will be changing settings constantly for the printer. Please let me know if I need to explain in better detail.
Feb 14, 2014 | Dell 2335dn Multifunction Laser Printer
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
I have a Brother IntelliFax 1270 (how is that for a dinosaur) and am getting a black line on the right hand side, when I cooy or send. Have cleaned around. I dont see any anwers but questions on this...
Check the docement scanner.there is a glass plate under it and see if something is stuck on it /look real hard its hard to see sometimes.Use a paper towel damp with water only.
Aug 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Problems of print docement
have you selected the correct USB port?
Jul 18, 2010 | Lexmark E250d Laser Printer
How do i scan on my brpther DCP-135C
there is scaner function as printer functino( which u load from printer driver. from there u can scan any docement-nepal
Feb 03, 2010 | Brother DCP-135C Flatbed Digital MFC...
Trying to scan a docement and the pc is sayiny no usb coneected and it is connected , And I have just updated from the net.
1.Check from My Computer > Device Manager Check USB Controller ensure Usb Printing Support was installed
2.Control panel add new hardware find driver and install driver again
3. Check USB port on your pc may be damaged
Oct 09, 2009 | HP Photosmart C4280 Aio Printer
Every time i scan a document i'm told i need the ocr software on my disk to edit the document. the disk tells me there is a problem. how can i scan and edit a document?
You have set the machine configuration up wrong You can save the docements in a .doc format and can use Word to modify them If you have scanned them in OCR you have created yourself a nightmare as all of the margins etc will be out I would un-install your scanner and re-install the software taking care of which boxes I was ticking Do not go for an automatic installation as it will put in stuff you will never use
Jun 07, 2009 | Lexmark X7350 All-In-One InkJet Printer
Error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
Computers & Internet Logo
David Payne
David Payne
