Question about Stanley Bostitch Coil Framing Nailer
How do you install Bostitch TVA6 Trigger Valve Kit
  • 2,176 Answers
FOLLOW closely, take a small pin punch and knock out the pins holding the trigger in place and then the 2 pins for the valve, one is probably longer. Next get a shop rag or good glove and holding back the collar that locks the air fitting to the tool push the chuck on the air inlet while holding your gloved hand or rag under the valve assembly. It will POP out make sure not to lock the chuck to the tool. Loghtly grease the o rings and make sure that you align the slots on the new one with the holes where the pins go. reassemble in reverse order.
Posted on May 08, 2010
How do i rebuild my bostitch n80 frameing nailer
Bostitch nailers are simple to rebuild. Bostitch company was sold to Dewalt so parts are now easier to obtain from local Dewalt service center. Use Ork11 oring kit and tva6 trigger valve. These parts are also available on ebay. Good luck or your nailing projects.
Sep 18, 2014 | Stanley Bostitch N80CB Coil Framing Nailer
Air is leaking at the trigger on a Bostitch 80s b1
Your nailer uses a trigger valve (could be part # tva6 cost about $20, need to look up) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good Luck on your repair and email if you have other questions
Oct 06, 2010 | Stanley Bostitch N80s Nailer -rebuild...
Air leaking out of the trigger area, no pressure at all
Your nailer uses a trigger valve (part # tva6 cost about $20) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good Luck on your repair and email if you have other questions.
Sep 04, 2010 | Stanley Bostitch N80s Nailer -rebuild...
My bostitch framing nailer is leaking alot of air through the trigger
Your nailer most likely uses a trigger, and the best place to purchase a new trigger is amazon. Take a look on this link Bostitch TVA11 Trigger Valve Kit I hope this was helpful. cheers
Jul 10, 2010 | Stanley Bostitch N80s Nailer -rebuild...
I have a N60FN Bostitch nailer. It's loosing air
Your nailer uses a trigger valve part # tva6 (or tva1, but use tva6) (cost about $20) and is sold at www.bostitch.com or ebay for generic. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body (Use punch for 3mm hole). Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. Note the two grooves on the side of the valve where retainer roll pins hold valve. Remember to insert the valve with these two groves aligned with path of roll pins. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring/seal on plunger is cause of leak. Try using an oring with smaller inside diameter than the broken or loose fintting seal that is present. It must fit pretty tight and be slightly thicker than 1/16" to work. Remove the outer orings to valve and clean and re-use same. Clean the valve port in body of gun and check for sharp edges to prevent cutting orings before inserting the valve. Use silicone lube or oring lube on the orings and the valve port (Danco silicone paste sold at Lowes in the plumbing department). Good Luck on your repair and email if you have other questions
Jul 08, 2010 | Stanley Bostitch Air Nailer Trigger N60...
Framing gun not firing leaking air aroung trigger
You have a crumbled trigger seal. You can order a new trigger valve through bostitch. It usually takes a couple of weeks though.. Every time I order one it is on backorder. You will need to order trigger valve kit part number TVA11 $21.40. Go to the Bostitch website click on Schematics and Parts to the left then find your model nailer in the search field and select item 53 when the parts list comes up. Click add to cart to order. Another screen will pop up and ask you if you want to checkout. Any questions please post back.
Oct 15, 2009 | Stanley Bostitch N88rh Framing Nailer...
O ring for bostitch n60fn
What you need is part # ORK1 and you can order it online from amazon.com The oring kit is $16.25. And if you also require a trigger valve assy it is listed on the page with the oring kit. The trigger valve assy is TVA6. Any questions please post back.
Oct 11, 2009 | Stanley Tools & Hardware - Others
Have a bostitch N60 with a trigger air leak
Your nailer uses a trigger valve part # tva6 (cost about $20) and is sold at www.bostitch.com. If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body(Use punch for 3mm hole). Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring/seal on plunger is cause of leak. Try using an oring with smaller inside diameter than the broken or loose fintting seal that is present. It must fit pretty tight and be slightly thicker than 1/16" to work. Remove the outer orings to valve and clean and re-use same. Clean the valve port in body of gun and check for sharp edges to prevent cutting orings before inserting the valve. Use silicone lube or oring lube on the orings and the valve port (Danco silicone paste sold at Lowes in the plumbing department). Good Luck on your repair and email if you have other questions
Apr 26, 2009 | Air Tools & Compressors
Bostitch n80 framer blow by by trigger asemably
Your nailer incorporates the (tva6) trigger valve. It is available online at www.bostitch.com, cost is about $20. To examine the valve, remove nails, remove retaining pin holding trigger, remove one or two pins holding tva6 valve (the pins holding the valve are in the body/handle just above the trigger. use punch that fits snuggly in a 3mm hole). Mark the valve in relation to the body of the gun. After several pins are removed apply air pressure to pop-out the valve. Use caution because the valve can came out with force. Reduce air pressure and use heavy glove to catch the valve. With tva6 valve in hand, notice notches on side of valve for roll pins. Remove two more pins to expose the inner valve. The middle seal of the inner valve is usually the problem, it could be cracked or fits too loose. You could try replacing the seal with a tight fitting oring. May work. or just replace the valve. Good luck with your repair.
Apr 20, 2009 | Stanley Air Tools & Compressors
Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Apr 08, 2009 | Tools & Hardware - Others
Stanley Bostitch Coil Framing Nailer Logo
1,351 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
