Question about Motorola Mobility SLVR L7 Cellular Phone
Mouthpease problems mouthpease voice problems
Cant understand a voice mail left on yahoo IM. sound is low and indistingusable
Maybe the problem is with the voice mail sent itself. Maybe it was recorded in a very low quality that's why what you receive was low sound and indistinguishable. Compare it with your other received voice mail, if all is like that then maybe there is something wrong with your messenger voice mail setting. If not, then the problem is probably the voice mail sent itself.
Mar 01, 2011 | Yahoo Messenger
Saanyo Spc 3200,When using the voice tag, It works one day and drop them the next day
Does not depend on the phone, is the phone company that provides voice message service.
Apr 02, 2008 | Cell Phones
Accidentally deleted voice nuvi250 garmin maps I have them updated, but can not find the voice, the explanations are in English. please help. thanks
The voice may not be deleted. The procedure below gives describes the steps to get the voice back even if it's deleted.
1. Press the Volume (Speaker symbol) in the bottom right corner and check that the mute box is not ticked. If it is press it and it will be ok. Also check that the volume isn't fully down.
If that doesn't solve the problem it may be because the voice file is not selected or has become corrupted or deleted.
2. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted or been deleted. To replace the corrupted/deleted file.
3. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 2 above.
Sep 14, 2010 | Garmin nuvi 250W GPS Receiver
Voice frequently not working. this problem intermittent. what do i need to do to ensure voice always works? Turning sound off and on again sometimes works. Turning on before using sometimes gets voice...
Are you using a synth voice, or a sampled voice? If the latter, one of the voice files might be damaged, and in that case, as soon as the Tomtom accesses it, the whole voice function will shut down.
Try changing the voice and see what happens. The synth voice does not access any sample files and should always work (or never at all).
To restore the functionality, download again the voice files, or try restoring from the PC backup. At least, this worked for me when I had the same problem (but MY file was damaged at the end, so I was able to notice that the last thing the Tomtom said was always "In sevent*". The damaged file was, I suppose, the one with the word "seventy".
May 29, 2010 | Tomtom GO 910 GPS Receiver
No sound / voice when getting directions
I had same problem a year ago while I was using it in the UK.
I think voice is contained in internal memory which was corrupted when battery went flat.
Problem was solved when I got home by doing a "hot sync".
If that does not work you will have to reinstall voice from your original disk
Aug 09, 2008 | Garmin iQue 3600 GPS Receiver
Laptop's Audio does not work in voice chat
There is a specific download for this. Your best bet is contacting Yahoo and asking them where to find it.
Jun 25, 2008 | Dell INSPIRON 6000 CENTRINO...
Problem with voice commander htc P3300
its a common problem with voice commanders...as one cannot expect a low end processing device to process your voice with 100% accuracy...even the best of best voice processors that run on high end computers are about 80-90% accurate...I suggest you reinstall the voice commander and re-create the voice tags...
Apr 23, 2008 | HTC P3300 Smartphone
Voice Navigation
Check your voice prompts.  make sure you are using either Jack or Jane.  the standard voice is the same as the voice on C330 which only gives you directions.
Oct 10, 2007 | Garmin StreetPilot c340 GPS Receiver
Voice Dialing Issues
I am sad to say that the voice recognition failure is permanent on most of the E815 phones. Your phone will likely never support voice dialing again, even though the cause remains unknown.
I too had the peculiar problem of pressing the voice button and hearing a beep, but no voice prompt ("Say a command"). When I researched the issue, I found a plethera of similar problem reports. Very few reported recovery after simply restarting the phone. I even found one report of Motorola tech support giving up and instructing the owner of the phone to have it replaced.
Feb 14, 2007 | Motorola Mobility E815
Motorola Mobility SLVR L7 Cellular Phone Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
