Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
Speedometer is 10MPH fast on 2003 Dodge Ram diesel.
I have a 2003 Dodge Ram Quad Cab 3500 Diesel SRW 4X4 truck. The previous owners must have had larger diameter tires and had the speedometer calibrated fot the larger size. It now has stock size tires (265/70/R17) and the speedometer reads 10 MPH faster. Can this be fixed by disconnecting the bateries for a period of time to reset the speedometer to default stock values ?
  • 524 Answers
THis is actually programmed into your computer so you are going to need to take it to your dealer or buy a tuner that is capable of this. Its embedded now and its going to stay until it is manually changed sorry. OTHERWISE you could always put bigger tires back on it and it would look mean!! :)
Posted on May 07, 2010
Looking for a fuse box map/diagram for 2007 Dodge 3500 diesel
In Owners Manual--If You Don't Have One, They Can Be Obtained From Dodge Dealer (parts department)
Feb 17, 2015 | 2007 Dodge Ram 3500 Quad Cab Laramie
How to remove front hub on 2007 dodge diesel
Check out the cummins diesel forums..they have great help and often step by step details with photos. I use them a lot.
May 31, 2010 | 2007 Dodge Ram 3500 Quad Cab Laramie
Speedometer not workingon an 07 dodge 5.9 diesel
speedometer sensor is out its on the tran. on the trail shaft
Feb 11, 2010 | 2007 Dodge Ram 3500 Quad Cab Laramie
2003 Dodge Heavy Duty Ram will not shift into 3rd gear
check your vacuum lines for transmission and do you flush and maintain your transmission?
Oct 07, 2009 | MTX Dodge Ram Quad Cab 2002-2003...
Diesel (exhaust) fumes coming through the dash air vents
a cracked manifold, donut seal,flex joint or egr valve
Oct 01, 2009 | 2007 Dodge Ram 3500 Quad Cab Laramie
How do you remove the flywheel when replacing the clutch
Take trans out, clutch out, and remove the flywheel bolts.
May 30, 2009 | 2007 Dodge Ram 3500 Quad Cab Laramie
Problems with Lift pump and injectors on a 2008 Dodge Diesel Ram 3500 Truck. What are our recourses?
we have a 2005 dodge diesel, has been in the shop 3 times for the same problem.! lift pump.,failure, and fuel filter failure,
Does any one out there have any feed back,?? I filter all of my fuel after i buy it , before it goes in truck.... This is getting expensive,, HAS ANY BODY ELSE HAD THIS PROBLEM???
Need a attorney and some advice..
STRANDED,,!!!!!
Aug 30, 2008 | 2007 Dodge Ram 3500 Quad Cab Laramie
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
146 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
