Question about Samsung Omnia Cell Phone
Backlight Dims when device is unplugged from ac adapter. I am running Spb Mobile Shell 3.5 and I have checked settings in all sections power, backlight, screen, and display. All settings confirm backlight is set to 90% but when unplugged the backlight dims to half and the settings remain the same.
4 Suggested Answers
RyanFanMan
  • 342 Answers
SOURCE: Samsung 46 " lcd backlight dims and brightens by
there is a light sensor that is for the backlight thatg if you refer to your manual you can find out how to turn it off
Posted on Mar 10, 2011
  • 129 Answers
SOURCE: I have samsung mobile D900i.
you have defective flex cable a ribbon type connector thats connect your screen to the main board of your phone replacing it will fixed your phone.
Posted on Jul 04, 2011
jmj105
SOURCE: samsung galaxy S3 screen dims when it goes to internet
is the phone on light saver mode or is the wire bad?
Posted on Jul 28, 2012
I want nokia c5-03 spb software rigester key
i want nokia c5-03 spb software rigester key
May 07, 2012 | Nokia 5800 Cell Phones
Nokia 5233 spb mobile shell register key
nokia 5233 users plz use this registration key to register your spb mobile shell application, no. is 8C59-8UN9-QGAY
Enjoy the application...;-)
Nov 08, 2011 | Nokia 5230 Cell Phone
How can i remove home screen icons
go to settings, select menu items you can uncheck items you dont want, if this doesnot work may be you have spb shell on the hom screen, go to settings , system and remove spb shell from icon add remove program. may need to restart if it is not getting removed
Dec 22, 2010 | HTC HD2 Smartphone
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
HTC Touch 3g clone (T3238) won't turn on, no lights, nothing!
Simply!
Power off the device, then hold the Volume Down and Enter buttons at the same time, then press the Power button.
A message should come up asking if you’re sure you want to do this, let go of the buttons you held down and press the Volume Up button to accept, or any other button to cancel the reset.
please note >> it is will delete all your data ...........!
Oct 05, 2009 | HTC P3300 Smartphone
Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Acer Aspire One A150-1006 Notebook
SPB mobile shell
go to ur program files, both location of ur storage card an my device location...then remove the folder SPB....also goto windows\program\and del the spb too..it will work
Mar 05, 2009 | T-Mobile MDA
Compaq Presario C700 Notebook Backlight only works on Battery Mode
First of all, let me inform you that there will be different brightness settings when the Notebook is running with Battery and Power Adapter.
I recommend you to try increasing the Brightness when the Power Adapter is connected to the Notebook by following the steps below :
Connect the Power Adapter to the Notebook and turn on the Notebook.
Now, hold the FN Key which can be found at the left bottom of the keyboard next to the Ctrl key and press the F8 button to increase the Brightness.
This should increase the Brightness of the LCD. Increase the Brightness to your comfirtable level and you are done.
Now, if you disconnect the Power Adapter, the display will appear either darker or brighter as per the previous settings with the Battery.
This is to save battery power like if the Brightness settings are same for both the situations like when the Notebook is connected with the Battery and the power adapter, battery will drain up fast.
So, if you can have different brightness settings for when the Notebook is running with Battery and Power Adapter, it is possible to maintain battery with low brightness.
Hope this helps.....
Oct 04, 2008 | HP Compaq Presario V2000 Notebook
Samsung Omnia  Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
