Question about Lexmark X2500 All-In-One Printer
Black Ink Cartridge error
Black Ink Cartridge not registering - Error reads "Incorrect balc Ink Cartridge installed" Not a new cartridge been in use for a few months but not empty
color cartridge was empty so i bought a black and threw away the color. now it says to inject cartridge or wrong combination. why would i have to have two cartridges to make it work with black ink?
  • kiki06 Mar 31, 2008
    I have a black and color ink cartridge but it is saying it is not the correct one. Went back to the place I brought the Lexmark x2500 from and still could not find the correct black ink catridge. Now it sitting here and I have never used it.HELP!!!!!
I ended up putting a color and black cartridge in and everything is fine.
Posted on Mar 28, 2008
Printer won't recognize ink cartridge
you can try by cleaning the copper contacts on the cart .. and if it works fine with the old cart i.e if it doesnt gives any error with the old ones then possibly the problem might be with the new cart..
Oct 23, 2009 | HP PSC 950 All-In-One InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Refillied black ink cart. causes error.
The ink cartridge is bad get a new one after a few times of refilling the ink cartridge they go bad. Hope this helps ya
Cheers
Johnthetr870
May 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer reads "Incorrect Print Cardtridge Installed"
According to the HP website, the correct cartridge for the HP PSC950 is HP15 or HP78. Comes in black only or tri-color.
Dec 22, 2008 | HP PSC 950 All-In-One InkJet Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Left Cartidge incorrect
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
clean the head With alcohol ,dry put it back
the head is jam !
Mar 10, 2008 | HP Officejet 4110 All-In-One InkJet...
Ink low error
Hi there the ink cartridges are designed to be used once. Most of these new ink cartridges have a set chip on it once you have installed a new cartridge it registers that a new one has been installed and resets the ink counter for that cartridge. When you refill the cartridge it doesn't reset the chip.
I don't know how to reset the chip but the best suggestion I can offer is to purchase a compatible cartridge that has been reset.
Thanks J
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
420 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
