Question about AEG L62600 Front Load Washer
E93 new modual fitted e93 comes up after 5min
  • 269 Answers
E93 is showing that the configuration code has not been put into the new Module if no configuration code came with the module then you will need to send me the p.n.c. of that model and I will get the correct code.
Hope this helps.
Good Luck
Posted on May 07, 2010
  • 1 more comment
  • studebake2 Jan 19, 2011
    I have the same problem. Replaced the module and now have a E93.
    I need the code for my AEG 74800 with PNC 914 016 032 00
    Could you give me the code?
    Would be most grateful.
    gr
    Heico NL
    ..Oh and yes...How can I enter the code?? Use the selector switch to select it and then accept by pressing a button? Which one?
    Thanx a bunch!
  • Christopher Dowling Jan 20, 2011
    Hi There,
    Tell me the part number of the PCB you fitted because there are 2 types for this machine,the one type is already configured and just needs fitting,then switch on then off and on again done.The other type is not configured but it would need special software licenced to Electrolux Agents like myself.Get back to me with that part number.
    Thanks.
My 2007 BMW E93 335i convertible roof will not come up. Lifted part way but is stuck.
You have likely lost hydraulic pressure due to low fluid from a leak in the system. It will take a dealer to isolate this leak and repair it.
Sep 02, 2016 | BMW X3 Series Cars & Trucks
Electrolux error 93
Good Afternoon Carolyn, this is Z. I am happy to assist you!
I see that you are receiving an error code E93 on your Electrolux dryer. Typically this indicates that the main control board has possibly gone bad or is not communicating correctly. I would suggest resetting power to your dryer for roughly ten minutes. If the error code still displays, at this point, I strongly recommend connecting with a local appliance tech that has the expertise to distinguish which part is the culprit. I hope this information proves useful.
Apr 05, 2014 | Electrolux Dryers
E93e error on dryer
You need a new control board ....
Mar 22, 2011 | Frigidaire GLER341A Electric Dryer
96 ram 1500 dosent run no fire no feul pump
did you change the modual in your distributor ?
Wires leading to the distributor ...take off cap and rotor ...modual is the one with the wires leading to it ...take out two or three screws ...unplug modual ...un screw modual ...buy new one>>>>>> reinstall
Jan 02, 2010 | 1996 Dodge Ram 1500 Club Cab
My 1978 ford bronco dies and doesnt want to restart. The motor has 2000 miles on it. It has a new electric fuel pump,coil distributor, cap,rotor, wires, plugs. it does the same exact thing with 2 diferant...
Float could be stuck, if it's carbureted or gasket under carb could be loose. Tighten and also put new filter in it. Could be bad injectors, if it's EFI which I doubt knowing the year. Could be choke setting wrong. I like manual choke myself. Try starting it with something holding choke open like a screwdriver handle. Something not too flammable.
Jun 25, 2009 | Ford Bronco Cars & Trucks
ABS indicator remains on
remove the brake lines and HCU. unplug the modual and istall new modual. if ou havn't had the van checked out, i would, there are a number of things it could be that are alot cheaper than a new modual. could just be a wheel speed sensor.
May 19, 2009 | 2001 Ford Windstar
Insert toner card? do I have another solution accept new toner?
I believe you are talking about the toner modual.
if you need to change the toner modual, you will need to tell the machine a new one is put in the machine.
Insert the card after you insert the toner modual.
The machine should prompt you that the modual has been installed.
If you have anymore questions about this, please let us know.
May 10, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Car run good for the first 5min, then its want to cut off
electronic lockup torque converter is bad had the same problem unless its very nice car cheaper to buy a new car
Jan 18, 2009 | 1988 Buick Reatta
AEG L62600 Front Load Washer Logo
261 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
