Question about Hifonics BXi1608D Car Amp
Why does the hifonics bxi1608d 1600 watt super D-class mono have 2 postive terminals and two negative terminals? would that cause my speakers to blow?
  • 524 Answers
That is still a single channel cass D amp. Each (-) and each (+) terminal are connected so its actually like only having one. This is so you can hook speakers up in a series circuit to lower impedance, because this amp is 1ohm stable. What causes your speakers to blow is too much power. What kind of speakers are you running? This hifonics amp is very powerful, they are getting big in the competition industries beacuse they put our true power for less money and they are tough. That 1600 amp you have may be putting out more like 1800 watts at 14.4 volts which is 900 per sub at 1ohm so be careful this amp has tons of power and its true rated its not like a sony or rocksford or kenwood that says 1800 max and then in small writing it says 500 rms. This amp puts out true. I have 3 hifonics amps and love them.
Posted on May 07, 2010
How to hook up 2Infininity dual voice coil speakers with coils and speakers wired in parallel to a Hifonics BRZ1200.1D 1200 watt super D-Class amplifier?
Wiring the voice coils and speakers both in parallel like this:
http://imgur.com/furO9yh
will be stable at 1 ohm mono.
Wiring the voice coils in series and the speakers in parallel like this:
http://imgur.com/jHSvmVU
Will be stable at 1, 2 or 4 ohms mono
I'm guessing ur subs are 4ohms by the way
Jan 23, 2015 | Dual Car Audio & Video
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
How to conect a hifonic amp class d to four
+ too - & - too + & + too - & - too +& + too -
Apr 01, 2010 | Hifonics BXi1608D Car Amp
Can a hifonics bxi 1608d support a half ohm
http://www.maxxsonics.net/manuals/hifonics/pdfs/HifonicsBrutus2009AmplifierManual.pdf
THE ABOVE LINK WILL ALLOW YOU TO DOWNLOAD THE .PDF MANUAL FOR THE CURRENT VERSION OF THE AMPLIFIER WHICH IS THE BXI1610D WHICH IS STABLE DOWN TO 1 OHM WHICH PRODUCES 1600 WATTS. YOU CAN ALSO CALL TO VERIFY THE MINIMUM IMPEDANCE OF YOUR AMPLIFIER BY CALLING MAXXONICS AT 847-540-7700......V
Dec 27, 2009 | Hifonics BXi1608D Car Amp
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
How do i wire up my hifonics sub to my 600 watt amp when the sud as two lots of postive and negatives
You can splice the wires together/double them up and make your connections that way.
Aug 25, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
I have a Hifonics BXI1208d mono subwoofer amp but i have 2 sets of wire terminals and they go negative negative postive postive. Which do I use?
Depends if its bridgeagle or bridge internally. bridgeing provides the most power to a mono system. 2 positives and 2 negative you have a 2 channel amp. Heres a link to check out, you should be able to figure out your system and hook it up with this. Hope it helps. http://www.wikihow.com/Bridge-an-Amplifier
Jun 20, 2009 | Hifonics Car Audio & Video
XX- ZEUS MONO D- CLASS / 1600 WATTS RMS
It's likely that the amplifier has shorted output transistors. If that's the case, they will have to be replaced. If you have zero experience with electronic repair, you should pay someone to repair it instead of trying to repair it yourself.
Let me know if you have any other questions.
Jul 28, 2008 | Hifonics BX1500D Car Audio Amplifier
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Hifonics BXi1608D Car Amp Logo
317 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
