Question about Fellowes PS60C-2 Shredder
My shedder quit working
The shredder was working fine, I emptied the basket, and now it will not run
  • 41 Answers
Check bag full switch and paper flap
Posted on May 11, 2010
SHEDDER NOT WORKING ?
If it is completely dead, check that the head is on the basket correctly as there is a safety switch in the base that is pressed by a pin on the basket.
If the motor turns but the shredder knives don't, and you have done lots of shredding, then the nylon teeth may have cracked. I have one in bits with the same problem.
At three months old, you can just return it.
Apr 28, 2016 | Royal Office Equipment & Supplies
I emptied the bucket of my shredder and now it doesn't run. It is only about 1 year old and isn't used much.
Check you have replaced the top on the basket properly, is it the right way round? If not on properly it will not feed power for safety!
Dec 29, 2014 | Shredder Office Equipment & Supplies
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
How do you empty the container?
You will first need to unplug your shredder. On either side on the shredder head, there are grooves. These are finger grooves. Place your fingers inside the finger grooves and lift up. This will remove the shredder head from the waste basket. Simply empty the waste basket, replace the shredder head and plug back in.
Jul 10, 2012 | Compucessory CCS 60062 Shredder
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
Red light for basket on will not let shedder run
Check for any photoswitches, they usually get wery full of dust from the paper.
Sep 29, 2009 | Fellowes DM15C Shredder
What is the interlock for a staples shredder
if you look at the underside of the shredder, you will likely find a pressure switch that is actuated when it sits on the stock bin, either modify it to touch when on the new bin or secure it so it is depressed all the time. This should allow it to operate on the replacement bin.
Hope this is of some help.
Ed
Apr 20, 2009 | Office Equipment & Supplies
OM 99727 shredder not working
I had this same problem. This is what I did to fix it.
When I went to ShredCare.com (the recommended web site for technical support of this particular shredder), I read that 'Most models of shredders have a safety interlock switch that is activated by the basket.' Upon looking closely at my basket and the shredder, I found this safetly interlock switch and made sure to align it with the proper position within the basket. There is only ONE way to place the shredder on the basket and have this safety interlock switch activated. The switch is located on the underside of the shredder. Align this switch with the ridge on the inside of the basket. Listen carefully and you will hear the switch 'click' when in the right position. Mine is very touchy. I've even had to press in on the side of the basket while shredding to make sure that the ridge and the switch are making contact.
Hope this helps!
Aug 15, 2008 | OfficeMax 0M96431 Shredder
Shedder Doesn't Work
Are you sure the saftety switch on the left side of the shredder is in contact with the small metal latch on the inside left side of the basket. The machine won't work unless the ssfety switch is pushed in.
Oct 23, 2007 | Aurora Global AS702MX Shredder
How to empty a Tech Solutions TS8000 shredder
Pull the top of the basket toward you and the top of it should swing out. Then you can lift the basket up and out once the top of the basket is partly open. Hope this helps. Have a good day. Mac =)
Mar 09, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Fellowes PS60C-2 Shredder Logo
251 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
