Question about Acer AL1711BM (Black) 17" LCD Monitor
My Acer LCD AL1711 went off after seconds of turning on.
Hi:
My Acer LCD moniter has started its problem two weeks ago, when I turn it on the screen comes a seconds then went off but there is still faint screen you can see. the green botton light in contiuously on.
I have changed all 4 capacitors but the same problem stays, so can you guide me to get my screen work again.
To be certain I have tried another moniter and it was working perfectly, this means the problem is in my LCD moniter
Thanks
Kaka
  • 4,234 Answers
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Posted on Mar 27, 2008
SOURCE:
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at [email protected]
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
My Acer AL1711 LCD monitor blacks out every 2 seconds. I like to try to replace the capacitors in it as it has been tried by few people here successfully. To tri this I took the 4 screws off in the back of...
take a flathead screwdriver and place it anywhere where the front bezel and back, you can start on the top, bottom, or either side of the monitor, place your flathead screwdrier and place it in any part of the **** and twist your screwdriver, this should start releasing some of the clips. I had to do this with several dell lcd monitors to get into them. Keep in mind after this there will be more screws to take out to get the lcd out of there.
Aug 04, 2009 | Acer AL1711 17" Flat Panel LCD Monitor
THE ACER MONITOR AL1711 BLINKING IN DIFFERENT COLOURS AFTER THE COMPUTER IS SHUTDOWN - TO STOP IT I HAVE TO REMOVE THE POWER TO THE MONITOR OR BEFORE SHUTTING DOWN I HAVE TO PUT THE POWER OFF FROM THE...
I just had this problem at work and what I did was I powered up the computer and went into the menu. I went to the 2nd to last button and selected the reset. It's working perfectly now. I do not know if it will last but it's easy and free.
Jan 23, 2009 | Acer AL1711 17" LCD Monitor
Al1711 Problem....
White screen is normally a problem with the LCD panel,generally difficult to repair
Samir.
Oct 25, 2008 | Acer AL1711 17" LCD Monitor
Hi: My Acer LCD moniter has started its problem two weeks ago, when I turn it on the screen comes a seconds then went off but there is still faint screen you can see. the green botton light in...
have you try to use another monitor? when its working there's must be a problem to your LCD monitor, but if does not.. there must be a problem to your video card..
Mar 26, 2008 | Computers & Internet
Samsung SyncMaster 152N Just died on me...
there is something that defect on the main board power input.
Mar 16, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Acer 1711, entering sleepingmode in few seconds
same prob on mine gues its the inverter board but not tried yet
Jan 13, 2008 | Acer AL1711 17" LCD Monitor
What is wrong with my AL1711
This is possibly an inverter. When the monitor goes out, examine the LCD to see if you can see a faint image of the video being displayed. IF so, replace inverter. If not, possibly a bad LCD or video circuitry.
Dec 07, 2007 | Acer AL1711 17" LCD Monitor
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
Open Questions:
See all Acer AL1711BM (Black) 17" LCD Monitor Questions
Acer AL1711BM (Black) 17" LCD Monitor Logo
201 people viewed this question
Ekse
Alun Cox
