Question about Garden
Sears front tine tiller....900 series, 24'' tire width...mod 917.299010.... won't start....no resistance at all when pulling rope..... removed rope assembly from r side of tiller....replaced & it started after shutting it off ...same thing happened again...no resistance at all on rope....the spring still pulled the rope back but did not turn flywheel...
  • 143 Answers
The pawl ratchets seem to be sticking for some reason, try some WD40 inside the recoil. Stephen.
Posted on May 07, 2010
Need to replace the pull rope assy. where can i buy complete pull rope assy
any accredited mower shop will have the assembly for your unit better if you can find a service agent for your engine.
May 01, 2015 | Sears 208cc Dual Rotating Rear Tine...
My Husqvarna FT900 tiller will not start
If this machine has been stood for nearly a year with fuel in it the fuel will now be stale, you need to drain the tank and refill with fresh fuel, if you are lucky it will fire up, if not you may need to remove the carb and clean out, remove the air filter and fire a small shot of fuel straight down the carb, this may encourage it to start.
Oct 13, 2012 | Husqvarna FT900 Adjustable Width Briggs &...
Refurbished ft900 will not start
did u replace gas and see if it is gettin spark it should still be under wanate
5.5 brigs and straton motor doesnt get any spark
try and spray starting fluid it might be carb related but if your sure its spark the coil is the only thing that controls spark
Apr 27, 2012 | Sears Craftsman 208cc* Front Tine Tiller...
Tiller Trouble 3/18/12
You might try using an upper cylinder lubricant to free it up. Use a very light oil such as marvel mystery oil and begin with placing a few drops on top of the piston - you will have to take the spark plug out in order to insert the oil. Let it sit overnight with the oil and then try turning it over with the rope. Hope this helps.
Mar 18, 2012 | Yard Machines Tiller 208cc 18in Tilling...
I have a 19" 7 horsepower dual rear tine tiller and can not find out what size belt it takes. It is a craftsman bought at Sears. I lost my manual for it.
If you're talking about the dual-rotation rear tine 900 series, produced by AYP, sold by Sears as Craftsman, also sold by Husqvarna, the actual belt size is 51-3/8". A 51 should work.
Apr 19, 2010 | Craftsman Rear Mount Tiller
My belt keeps coming off on my tiller its a 24
There are several possibilities:
1. the belt is old and over stretched and needs to be replaced.
2. you have a bent shaft that causes the pulley to speen crooked.
3. The pulleys are not lined up. You should be able to adjust them by loosening them and sliding them back and forth on the shaft.
Mar 09, 2010 | Craftsman Garden
Garden Logo
301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
