Question about Bosch Ovens
I have a BOSCH HBN 4305.1 B oven. The clock and timer are working fine but the oven will not heat up and the light does not go on. It has not blown a fuse as the fuse box did not trip, any ideas? It was workinfg fine until tonight.
2 Suggested Answers
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
Tip
Common heating faults with Bosch HBN 560570B / 560550B single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
Tip
Common heating faults with Bosch HBN 131560B / 131520 single oven
on Jan 19, 2010 | Bosch HBN 131560B / 131520 hot-air...
Tip
Common heating faults with Bosch HBN 442 / HBN446 single oven
on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Bosch electric single oven (hbn 4305)
    Dec 08, 2007 | Ovens
    Oven will not heat?
    you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
    Jun 12, 2007 | Bosch HBN 43L550B SS Electric Single Oven
    Ovens Logo
    116 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
