Question about Toshiba SDK990 Player
Toshiba sdk990 hdmi is not working. I tried to connect using HDMI cable but no output. I am having sharp - LC32d40u LCD tv. samd HDMI cable is working fine my laptop to tv connection.
SOURCE: Toshiba RD-KX50 HDMI freezes the recorder.
Same problem with a Panasonic TC37LZ800. Talked to Toshiba Customer Support. They are sending me disc containing a firmware upgrade. Hope it does the trick.
Posted on Aug 25, 2008
SOURCE: Changed HDMI settings and can't now see image on screen
I did the same thing, if you hold the hdmi select button on the player (not the remote) while ejecting and inserting a dvd, it will reset so you are able to access the setup menu again.
Posted on Feb 18, 2009
SOURCE: YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Posted on Sep 23, 2009
SOURCE: Toshiba sd-5000 just not playing. all HDMI cables
I got the same problem today. I thought it was a connection on HDMI cable problem. I tried many different options to solve it but nothing was working. After I read your post I realized that my 2 y old boy was playing with the remote before it happened. So I found on menu in DVD player option - default setting- and I pressed it - and bingo - it's working. I used cinch cables instead HDMI while I was fixing - just in case you cannot get the menu screen on tv - good luck
Posted on Jan 30, 2010
  • 8457 Answers
SOURCE: My toshiba sdk990ku dvd player stopping playing
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Posted on Nov 18, 2010
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
No sound output
Check that the audio output you have selected on your computer is going out on HDMI cable. If your sound card will not process HDMI output you will never get sound. Changing HDMI sound from computer to tv
Mar 26, 2014 | Toshiba 32C110U 32 in. LCD TV
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
My toshiba sdk990ku dvd player stopping playing the audio. Have connected via HDMI to LCD HD tv and worked for months! One day audio stopped, but picture is fine. Tried different HDMI cables, dvds with no...
Nov 18, 2010 | Toshiba SDK990 Player
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Dec 15, 2008 | Sharp LC52SB55U LCD TV
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
HDTV picture staticky, cuts out
I suggest contacting Sharp directly. I just did and received absolutely nothing from them. But if others such as myself who have the exact same problem as you ( I own a LC32D40U just over 2 yrs old) contact then maybe something can get done.
I will certainly NEVER recommend a Sharp product to anyone and will as of this moment respond to every message out there letting everyone know exactly how bad Sharp's product are. I would recommend the Sony XBR series to anyone looking for an LCD television.
Dec 03, 2007 | Televison & Video
Toshiba SDK990 Player Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
