Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
The steering wheel turns but the front wheels only move when the gear on bottom touches the other gear it will catch sometimes when you turn wheel
  • 143 Answers
Either the gears are worn or sheered or the bushing holding the steering shaft is worn and needs renewing.
Posted on May 07, 2010
Tightening steering wheel on husqvarna tractor 42in 15 horsepower no. yth1542
Interesting! The steering gear can commonly become loose at a several points. I would check the steering wheel itself, prise off the central plastic cover and make sure the nut underneath is tight. Check the gear at the bottom of the steering wheel shaft, if this gets loose it can jump the gear teeth. Sometimes this is so bad the steering wheel will turn without moving the wheels. Tighten everything and replace any worn parts.
Jun 13, 2016 | Husqvarna Garden
Tip
Rack and Pinion steering gear RnR 1995 - 2005 Chevy Monte Carlo and Impala (FWD)
To start: Make sure the steering shaft and or wheel is not turned during this repair =|= You can damage the air bag system coil. Put the key in and lock the wheel or use a seat-belt and tie off the wheel so it will not turn.  Take the battery loose. check your radio for any codes to reset it after finished or turn off the lockout before you disconnect the battery. If you have a 3.4 DOHC engine remove the air cleaner and duct work.  You will have to jack up the front of the car and make it secure with good supports and locking the rear wheels, You will be under the car so - be safe, be sure, be safe. You have to remove the front tire/wheels and your jack stands have to be behind the front sub-frame, you can not use the sub-frame for support during this job. Set the wheel straight ahead. Pull back the boot at the bottom of the steering column shaft, mark the coupler and steering input shaft.  If you have the 3.4L DOHC remove the right side engine splash shield, and the exhaust pipe / catalytic / converter  assembly .  Separate the tie-rods ends from the steering arms, count how many turns it takes to remove them. then you can some what preserve your front-end alignment. Support the rear of the sub-frame with a jack giving room to access the rear most part of the sub-frame. Remove the rear sub-frame bolts, loosen the front bolts Do Not Remove them!!! lower the rear approx 5 inches DO NOT LOWER TO MUCH YOU CAN DAMAGE SOME ENGINE COMPONENTS.  Remove the heat shield form the steering gear. Take any pipe or hoses loose form support clips on the body. You will need a drain pan to catch any fluid that drains out. Using a flare nut wrench take loose the pressure and return lines from the gear. Plug the lines to stop fluid from draining out of the lines. Remove the gear retaining nuts and bolts. Pull the gear out of the supports move it forward and detach the steering coupler from the steering shaft. Support the gear and it comes out the left side wheel opening.  To reinstall pass the new gear through the left wheel opening and place it in position in the mounts reinstall the shaft coupler and the bolts/nuts in the supports. reattach the lines, the heat shield, and if you can find them you should use new sub-frame bolts, run the rear in first and then the front, one at the time and torque the bolts to 133 ft-lbsReconnect the tie rods to the steering arms. Reinstall the exhaust system now. Check the wheel center using the marks made on the shaft, be sure the coupler is seated before you tighten the pinch bolt. Reinstall the front wheels, lower the car off the stands. Reconnect the battery. Fill the power steering pump to the recommended level start up the car and ck for leaks, have the alignment checked per a tire / alignment shop.
on Dec 22, 2009 | Chevrolet Monte Carlo Cars & Trucks
Why want my tractor turn every time you turn the wheel
Hi Tuffy:
If you look at the linkage, the bottom of the shaft from the steering wheel will probably have a gear that connects to the steering quadrants. It may be that the parts are worn or are loose so they don't engage properly.
This will be a project that takes a bit of time and patience in
- looking at the pieces to see where it's not working, and
- determining if you are capable of repairing it.
Jul 25, 2015 | Cars & Trucks
I have a 2005 Pontiac grand am and every time I go around a corner, doesn't matter if its a left or right turn, I hear what sounds like a grinding noise coming from the front of the vehicle near the...
this might help:
Here is the Technical Service Bulletin that maybe of help, worth looking into but can't guarantee that it would fix your problem Steering - Steering Column Clunking When Turning TECHNICAL Bulletin No.: 01-02-32-001P Date: November 25, 2009 Subject: Clunk Felt/Noise Heard From Steering Column, Steering Gear and/or Front Of Vehicle During Turning Maneuver and/or Steering Wheel Rotation (Replace Intermediate Shaft As Directed) Models: 2001-2004 Buick Regal 2005-2008 Buick Allure (Canada Only), LaCrosse 2000-2008 Chevrolet Impala 2000-2007 Chevrolet Monte Carlo 1998-2002 Oldsmobile Intrigue 2004-2007 Pontiac Grand Prix Supercede: This bulletin is being revised to add the 2008 Buick LaCrosse/Allure. Please discard Corporate Bulletin Number 01-02-32-001O (Section 02 - Steering). Condition Some customers may comment on a clunk type noise coming from the front of the vehicle while driving during a turning maneuver.
1. Locate a large area (parking lot) where the vehicle can be turned in a tight circle. 2. Turn the steering wheel to the right and/or left all the way to the steering lock, then off the steering lock a 1/4 turn. 3. Drive the vehicle approximately 5 km/h (3 mph) in a circle, preferably over rough pavement or seams on the road surface. 4. Drive the vehicle straight ahead at idle speed while applying and releasing the brake pedal. Listen/feel the steering wheel for the clunk/noise condition. 5. If a clunk is felt in the steering wheel, the MOST likely cause is the I-shaft - not the steering gear. Continue with the correction. Correction DO THIS - Replace the intermediate shaft DON'T DO THIS - DO NOT lube the intermediate shaft Replace the existing intermediate shaft
Apr 13, 2013 | Cars & Trucks
98 Chrysler Town & Country Ignition, steering wheel & gear shift are all locked up. Last night we stopped to get some fast food. When we came back out to the van, it would not allow us to move...
Sometimes the mechanical system that locks your steering wheel has too much vehicle weight which can prevent the key from turning. If you can move the vehicle back and forth while someone turn the steering wheel and turn the ignition switch.
Jun 27, 2017 | 1998 Chrysler Town & Country
My key is stuck on acc. Car is off, no power and cannot move the gear shift or remove the key. What should I do?
check the fuses at the front passenger foot well, the middle one on the top that's halfway pulled is for the solenoid that releases the key. its also for the rear right turn signal so you should check the wiring there too.
Jan 12, 2011 | 2008 Buick Enclave
How do I align the steering after I replace the steering gear box so I have equal rotations on the steering wheel from left to right on a 1992 chevy astro van?
with the front of the vehicle raised in the air (with jack stands underneath), turn your steering wheel lock to lock, counting how many times the steering wheel does one complete rotation..........halve this number and rotate the steering wheel the opposite way...this will be the approximate middle of the steering rack movement
One important ppoint to note that not all items are built exactly, so you will require a wheel alignment after any change in steering or suspension components to be sure that everything is running true and correct
Aug 02, 2010 | Chevrolet Astro Cars & Trucks
My steering wheel is vibrating really bad and I can't turn the wheel
If you cannot turn the front wheels and the steering wheel was vibrating before then (since I assume that the car is undrivable now), then your car most likely has broken/damaged tie rod: check if the front wheels wobbles.
A less common problem is the actual steering/wheel rack-pinion gearing mechansim is broken and it is indicated by not being able to move both the front wheels together.
In both case, you need specialist repair.
Hope it helps.
Jan 28, 2010 | 2007 Lexus IS 350
Cannot get key to turn in jeep. Have already driven it numerous times today, suddenly can't move steering wheel or gear shift and key will not turn. Help!
Try turning the steering wheel (hard) right and left while turning the key. Steering lock , and ignition lock work in conjunction with each other.
Nov 06, 2009 | 2004 Jeep Liberty
Sloppy steering 96 Ford Bronco
You need to check all of you front steering components have someone turn the steering wheel back and forth. While you lay on the ground check all joints and components for play then check your steering shaft under the hood see how far steering wheel moves to each directions to when your tires start to move your gearbox has an adjustment on it that can be adjusted it looks like a screw with a nut at the bottom loosen nut a few turns and hold it with a wrench then take screwdriver and turn screw about 1/4 keep checking wheel for play you can tighten to much so keep checking that wheel turns back when you let go if you have any loose joints undernieth replace that part
Jun 22, 2009 | 1996 Ford Bronco
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
354 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
