Question about ASUS WL-500W Router (WL500W)
ASUS WL-500W not connected to the internet
I set up my ASUS WL-500W and I'm able to acces the configuration at, but not the internet. I have tried it on 3 computers(XP and Vista) , both with cable and wireless, with the browser setup and the CD application. I have upgraded the firmware. But it still is only able to connect localy.
Thanks in advance
  • Hollyecho Montgomery
    Hollyecho Montgomery May 11, 2010
    It most likey is the modem is not set in "bridge" mode, what is the model of your modem?
    Problem Solver:
  • 7 Answers
How your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Posted on Mar 28, 2008
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point,review-233-3.html
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Have a comcast modem would like to hook up a wl-500w router
For that Connect your router to computer with ethernet cable then you can access it with following default link.
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it
Still same then you need to reset router for access it with above default ip.
For that press RESET button it is in back side of router press it for 10 seconds then try with above ip..
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 16, 2010 | ASUS WL-500W Router (WL500W)
I have got an asus wireless router wl 500w . I can only get local acces, and sometimes connection to the internet for aout 10 seks, and then theres no interne again
connect to it using a rj45 cable and type into your browser.  if that doesn't bring up the router config, you'll need to find out the ip by clicking start>run> type cmd enter.  then type ipconfig and see what the router assigned  your ethernet card.  type that in, except for the last triplet of digits, type 1.  once you're there, login using admin and a blank password or admin and admin for password (differs from router to router) and see if your wan connection is set to automatic or manual.  if you're using dsl, you'll need to manually configure your connection.  cable does not require configuring and can be set to automatic.
May 18, 2009 | Computers & Internet
Asus wl-500w and modem
your sub net mask is wrong you have to put and make to modem and to router
Apr 11, 2009 | ASUS WL-500W Router (WL500W)
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Intermittent WiFi with ASUS WL-500W
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
May 16, 2008 | ASUS WL-500W Router (WL500W)
Asus WL-500W USB printer - Can't add printer
Fixed it, remember to install the vista driver for your harddisk, then select the port of the ip to the wireless devide, then it should work, you can check in the wireless web setup that the printer is located, under System.
May 12, 2008 | ASUS WL-500W Router (WL500W)
Open Questions:
ASUS WL-500W Router (WL500W) Logo
338 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
