Question about Samsung SM400P 40" LCD Monitor
Xtratech crt monitor vga cable resolding
5 Suggested Answers
jemmyrash
  • 180 Answers
SOURCE: Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Posted on Apr 19, 2008
skotkolr
  • 558 Answers
SOURCE: my crt redfox deskpod monitor wont start. It just
bad high voltage , time for a new monitor sorry
Posted on Mar 21, 2009
technical114
  • 1851 Answers
SOURCE: VGA CABLE PROBLEM
Here is the pinouts for the VGA cable. What is your problem?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 07, 2010
  • 109 Answers
SOURCE: VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Posted on May 17, 2010
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
LG Studioworks 700S 17" CRT Monitor, on screen
Dear Sir,
This problem is not from monitor side,check computer RAM.Clean it twice and reinstall it on place.If you are using VGA card then disconnect it from PCI slots and connect VGA cable to on board VGA . I think it solves your problem.Let me know
Jan 08, 2011 | LG Studioworks 700S 17" CRT Monitor
Broken vga cable
If the cable is to a CRT monitor this will require and new cable harness to be rewired to the main board of the CRT which will cost a lot to replace if the cable can be obtained usually not successfully due to the fact that most CRT monitors are manufactured in Asia.
Mar 03, 2010 | ViewSonic E70f 17" CRT Monitor
Apple multi scan 20 display. Screen works fine but green is predominant. How and where do I adjust the green intensity?
This can be adjusted by the RGB settings on the menu (monitor setting menu button on the monitor), Brightness color contrast also helps.
That is providing that its the settings thats causing your problem. In my experience the VGA cable sometimes shorts out producing that green hue. You may need to shake the cable a bait to see if it clears up or causes weird iterations. Once this happens it means the cable is shorting. It could be a broken solder to a broken wire. Replacing the vga cable and resoldering the connectors inside the monitor (where the cable jack connects to the main board) fix's the problem.
Feb 25, 2010 | Apple Multiple Scan 20 20" CRT Monitor
Monitor plain raster ok but nodisplay (or) no image
check video output ic and resolder..then check vga cable..
Jan 04, 2010 | Samsung 793S 17" CRT Monitor
Apr 02, 2008 | Computers & Internet
Display green,red
It should be dry solder joints on the CRT board,the picture tube base is normally dry solder.
Opening the monitor could be tricky as there are two plastic locks which hold the top end of back cover.
Samir
Mar 09, 2008 | LG Studioworks E700B 17" CRT Monitor
Samsung SM400P 40" LCD Monitor Logo
254 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
