Question about Lincoln Conveyor Oven - 1132-000-A
Does lincoln 1450 series oven do the same job as lincoln 1000 ovn
My lincoln 1000 oven just died on me three diff repair man worked on it
and cost me already $1500.00 and no one can fix it, the problem from
what they tell me is the pilot igniter, and the gas doesnt get thru i guess , I am not technical so really dont know , so I decided to buy another 2 year old 1450 licoln, what i want to know, whats the diff between 1450 and 1450 digital ?> and does it do the job the 1000 was doing >>>??we use the 1000 modle to bake flat bread on it same as pizza 16 ''
  • 106 Answers
The 1450 Lincon and the 1450 digital basically does the same things only that the digital is more advance in that it is has mother board whith digital control. it is more acurate in its sttings eg acurate time and acurate temparature setting. It also can give diagnostic massages within the control.
As for your lincoln 1000 series please try and give me the detailed problems, im sure i can help cause i have over 8yrs experinces with lincoln pizza ovens
Posted on Jun 16, 2010
  • Marcus Bramhall
    Marcus Bramhall Feb 18, 2011
    The 1000 platform up to the 1450 are about the same. The same main blower motor except for the old and loud 1000 series. The main difference is how the high flame is maintained(temperature in the oven). The old 1000's used a mercury switch and the newer models use a electric solenoid valve.
    If you want to sell your old 1000 I would be interested in buying it from you. Our shop takes in Lincolns and refurbishes them to current standards.
    Marcus Bramhall
    Shimmmer LLC
    318.202.2022
    206.769.4466
I have a remanufactured lincoln impinger 1000 gas conveyor pizza oven which I believe was converted to a fast bake 1450 model and the main fan motor on the back is screaming.
If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Apr 29, 2014 | Lincoln Ovens
The burner dont light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 18, 2011 | Thermador Professional Series PO301...
LINCOLN IMPINGER MODEL #1450 1994 YEAR. OVEN BLOWES FUSES SOMETIMES AND TAKES UP TO 5 MIN TO START UP. WHAT CAN BE WRONG?
Sorry I sent you the 1600 series manual.
Here is the 1400 manual
http://lincolnfp.com/docs/uploaded/lin/products/Impinger_I/L371075%20-%201450%20Series%20Gas%20Service%20Manual%20-%20Domestic%20-%2010_21_09.pdf
Nov 02, 2010 | Lincoln Ovens
Can i change the Lincoln 1000 Main Blower Motor my self if i get the right parts?
Yes, if you are a bit handy man and you have the following tools,
1.Set of rachet set
2.A couple of scrow drivers and pliers
3. A blow torch to heat the core of the fan blade.
4. A pully remover.
Herr is a question
Why do you need to change the main blower?
is it noisy and you need to change the bearing?
is the motor burnet out? this case is one out of 100 case.
let me know.
Thanks
Harry@pizzaequip.co.uk
May 20, 2010 | Lincoln Conveyor Oven - 1133-000-A
Trying to replace UY46x grill element, unfortunately conecting wire has dropped down and cant retrieve, can I remove the grill backplate to get to the wire ?
You need to take ovn out of its cavity and take the back off. You will then see the wiring. Easy job. You may need to place oven on a table or similar as wiring may not be long enough to put oven on floor and they can be a bit heavy
Oct 22, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Gas conversion kit
If the manufacturer can't or won't supply one, check with your local LP gas supplier, if they dont do this type of service they can likely refer you to someone who can, This is not a typical "do it yourself" type project, if its to be used in a commercial application, an unapproved conversion may render the oven unsafe to operate causing a structure fire and bringing down the wrath of your local fire martial.
Aug 15, 2009 | Lincoln Conveyor Oven - 1133-000-A
Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Aug 23, 2008 | Whirlpool RBS305PD Electric Single Oven
KitchenAid Architect Series KEMC308KSS
what if we have a voltage problem in the house, then it would be a lot cheaper to have a ceritifed electrician look at this beacuse there has to be a connection that the service man is overlooking than to purchace a new double oven at a tune of 1500.00
clll me 276-523-4434 David
Apr 12, 2008 | KitchenAid Architect Series KEMC308KSS...
Open Door Message
are you positive the switches are good?those switches go back to a relay board,turn off the unit and trace the wires from the switches back to the board.lighty tap on the relays (they could be stuck closed prompting that message}.if that doesnt work the relay board may be bad and yes they are expensive but i think $1000 is on the high end.
Aug 13, 2007 | KitchenAid Architect Series KEMC308KSS...
Lincoln Conveyor Oven - 1132-000-A Logo
410 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
joneable
Level 1 Expert
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
