Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
My screen keeps losing the red colour
The screen has a more green colour because the red colour keeps coming and going. I tried using different inputs on the t.v and using different DVD players and RCA cables and it still doesn't help. Can anyone help me narrow down the problem. I don't know if it's worth fixing or just buy a new tv.
  • yamaman1974 May 07, 2010
    Is there anything I can do to diagnose it further?
  • 178 Answers
Not absolutly sure but it sounds like one of the crt's are starting to fail. Sony has a white balance circuit that constantly will attempt to correct for white balance errors, if it has a hard time fixing the white balalnce what you describe can happen. Durring these events your tv's power button can blink in repeating pattern of 5 blinks indicating an akb or auto white balance error. Eventually the picture may flicker on and off or the tv will shut down all togeter with a 5 blink error. But i cannot be sure without looking at it myself. There are other causes aswell; focus block, or a crt driver can cause simular issues. But given the age of this set i feel it is a better chance one of the crt;s are going bad. But again it could be the other things i mentioned.
Posted on May 07, 2010
  • zapdbf May 07, 2010
    Not without taking the tv apart. I would try several simple diagnostics like adjusting the g2 and see if it stabilized, if it did i would replace the focus block, if that did not work i would test the crt's with a crt analyzer and see if one of them has low emissions. The diagnostic gets fairly technical following a path of clues to get to a solution. I don't agree with the person presenting solution #2, I would be ashamed if it took me 3 months to develop a diagnosis for this issue. A good tech should be able to give you a good idea of the issue in home or at least the shop tech should be able to diagnose this fairly quickly.
  • 160 Answers
You have already done all of the trouble shooting. The t.v. will need to be serviced, and the time and cost of having the tv repaired is not worth it in my opinion. Most repairs such as this will take a service center 3 months to diagnose, order parts, get parts, and install parts. Even then the issue may return. New LCD's have dropped greatly in price and is what I recommend.
BEKO 32WLU530HID only red colour except on internal Menu
Sounds like a loss of green--I am in USA and Scart term not used here but I am aware it began as internet slang for Component hookup--which does use a Green, Red, and Blue input cables---if that type then suspect no green from source or cable bad etc.
Apr 25, 2012 | Televison & Video
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
Sep 13, 2011 | Televison & Video
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
I have a RCA Hd52w59 television that has a blurry red green blue colors on screen and the pics looked like they are caved in .any help ?
RED BLUE and Green are the component colors. If you are using component cables, which most likely you are, check to see if the Green has come unplugged. Try switching the cabls to a different input. Actually, if you get the same problem on another input that say....your DVD player is hooked to, you have a bad tv. If not, try to isolate it to the simplest thing first e.g. cables, input source, etc. Please don't forget to rate this solution for me.
Jan 21, 2011 | RCA HD52W59 HDTV Projection Television
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Connecting old DVD player to LCD
Just respect the colors. Green output from the dvd to green input tv, Red output from the dvd to red input tv and the same with blue. All 3 cables (green , red, blue) are for the picture, so you got to plug another 2 for the sound.
Dec 25, 2007 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
192 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
