Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Gas before i start the mower is there a button to pump
    Scholar:
  • 110 Answers
No. Just get on and crank the engine.
Posted on May 08, 2010
Why doesn't B & S engine start?
pull the carby and clean out the corrosion blocking the main jet
Apr 22, 2016 | Garden
Mower will start but won't keep running, it will start right away but it will shut down again. it has very little gas on the gas filters the gas filter is new but it looks empty... can this be a fuel pump...
Yes it could be. I would disconnect fuel line from carb, put this end of fuel line over a bucket, then turn starter over to check fuel flow. This should tell you quickly if your pump is working or not. Good luck!
Sep 18, 2013 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
My 25 horse kohler starts when I put gas in the carb, then shuts off. I have gas from the fuel pump--HELP!
first check for power going to the solenoid on the bottom of the carb its a anti backfire valve if you have power there when the key is cranking and when turned on the solenoid might just be stuck if that works maybe the gas that was left in the carb turn bad
Apr 10, 2012 | Husqvarna Garden
Brand new 550! push red pump button 3-4 times... pull handle..mower starts up then dies. Will not continue to run..
Sounds like wet fuel! The priming puts enough gas in to start it but the running circuit does not.
Check your gas can for a layer of water on the bottom of it. If it has a lot of water in it you should dispose of this fuel at a gas station that collects used oil and gas. Drain the mower and take that gas away too.
Put in fresh gas from a known clean and dry source.
Let me know what you find ok?
Good luck and be careful!
Jun 29, 2010 | Craftsman 550 Torque 22 in Deck 2n1 Side...
How do you start a new toro 6.5 hp lawn mower. I borrowed it from my neighbor,but it has 2 levers to pull back. I'm clueless!
One lever is to make it go - wheels will turn & pull the mower..
The other lever is to keep it running - it this lever is released it will shut off..
This is the lever you need to keep pushed for it to start..
When starting - there should be a rubber push button on the engine near the carb.. Push it 4 times before starting.. This pumps gas into the carb for quick starts.. Good luck ;o)
Jul 08, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman lawn mower can not run without pumping the red button
The fact you need to keep pushing the RED or "Primer" button says that your engine is running too lean ie. not getting enough gas.
You probably have a carburator problem due to the old gas gumming up the inside of the carb. The gum and dirt is clogging some of the internal passages of the carburator. It will need to removed from the engine and cleaned. The carburator is held to the engine by 2 bolts and is simple inside. Carefully clean the carb. with either carb. cleaner or laquer thinner or similar good solvant. Reinstall and you should be fine.
Also be sure to check your air filter and replace if dirty.
The red button is a "primer" that pumps extra gas into the engine. It is normally used only only for statrup so if need to use it while the engine's running, you're running too lean.
Dr of Motors
Mar 21, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
16 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
