Whirlpool top loading washing machine (maybe 5 years old)has 2 problems 1) in regular load wash it fills with water, agitates but when it gets to the part where it has to drain, it may start to spin and drain (sometimes I have to push down on the door latch button that tells the machine the lid is closed to get it to advance with the spin & rinse part) but then (Only in regular cycle mode) the machine starts to make a funny (mooing sort of) sound and blows the breaker shutting off all power in the house. Ummm...seriously. so the 2nd problem is that I have to push the button down to get the cycles to advance in delicate cycle (in delicate it doesn't blow the fuse!) Any and all suggestions would be awesome! Thank you!
  • meshad711 May 07, 2010
    Thank you very much! I appreciate your honest assesment and advise. I thought the motor may have been zapped and that that was throwing the power but wanted an expert opinion. Now I've got one. Looks like a new washing machine in my future :)
    Thank you again for your time.
    Mesha
    President:
  • 949 Answers
Thank you for the detailed symptoms! They are explained well enough for me to give you a diagnosis that I am 95% sure of.
You are correct, you have 2 separate problems.
#1 Lid switch, part number 3949238, the lid switch sounds like it has too much play in it, this can happen internally or the outer case of it can crack, either way it needs replaced, it runs about $40.00
#2 Motor, it sounds like the high speed windings on the motor are bad this could cause the motor to labor and draw high current during the spin when the most load is on the motor. It runs about $190.00
It is a hard decision to make, but even though this in only 5 years old I would think hard about putting this much money into the washer.
Let me know if you have questions.
Posted on May 07, 2010
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Sm8280867
See if all the connections are tight; try inter-changing the water pipes. Water should have good pressure at faucet.......
Apr 27, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
GE top load will fill with water, not spin, agitate, empty water
very familiar with this look under machine if black dust found it has a broken motor coupler, very easy to change
Dec 22, 2008 | GE WDSR2080D Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Duet Front Load Washer
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
It's slow to fill
It's overfilling
It's underfilling
Hope this may help;
Aug 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
