Question about Canon Office Equipment & Supplies
My copier show E000. and who can enter in service mode
  • 1,219 Answers
I pressume that it is canon copier, E000 means that you have fixing temperature problem.
If its newer model eg. with "iR" markings, you enter with * 2 8 * and under COPIER-FUNCTION-CLEAR-ERR, then turn off and on. If do not help you need to change fixing film unit.
If it helps be sure that you have a good air circulation around copier, do not have A/C blowing into copier,...
Posted on May 10, 2010
My Machine Shows eror E000 I Repair this eror But I can't reset my machine. Please Help me!
You have cleared the error by entering the service mode or not?, it is not the case, entered the service mode * 28 * and go to the menu option and clear error and reset the machine
Nov 08, 2011 | Canon imageRUNNER 400S Copier
E000
if I remember corect E000 means that inadequate rise in temperature of the fixing unit at power-on
You must enter in service mode end acces the menu CLEAR and activate ALL.
You can enter in Service Mode like this:
press Service Key, press # key
press left arrow until CLEAR appears on display
press OK
press left arrow until ALL appears on display
press OK, the machine restarts and you should be able to use the machine.
Nov 18, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
E code E000-00-0081
hi, check once again if it's E000-00-0081 code. i just looked in the service manual for that machine and there's no E000-00-0081 code. the only one pointing to E000 is this: insufficent temperature rise of the fixing unit at power-on.
the one pointing to 0081 is:
p-sens-p when value of this position is lower than 255 it will indicate an error code: E020-0081. you can check it in service mode which you can enter by pressing combination: *28*(star-28-star) try specifing some more detailes, e.g. when it occurs
Jul 24, 2009 | Canon imageRUNNER C3170I Color Copier
As to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Mar 13, 2009 | Canon iPF700 InkJet Printer
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Jul 16, 2008 | Canon ImageRunner 1600 Copier
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon D861 copier
Garner,,, the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister).
IF YOU'RE GAME, here it is...
To enter service simulation: press"Additional Functions" to enter "User mode". Press # key. Press </> to select a menu item. enter new data using number keys. Press "Set/OK" key. Press Stop/additional functions to exit.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET."  Power the unit off/on.
Oct 11, 2007 | Office Equipment & Supplies
64 people viewed this question
old marine
old marine
