Question about Maytag 30" Self-Cleaning Slide-In Gas Range - Stainless-Steel
Maytag gas range (CHG9800BAB) When i turn the
Maytag gas range (CHG9800BAB) When i turn the oven on, i cannot increase the temp past the preset 350 degrees. i can however, lower the temp
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
  • 1462 Answers
SOURCE: Maytag MER5775Q Electric Kitchen Range
heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
Posted on May 18, 2007
SOURCE: GE XL44 Spectra Gas Oven Range
Replace the electric ignitor, I did today... Temps are hotter than ever. $60 from an appliance suplier, easy to install.... Trust me
Posted on Jun 30, 2008
BarrettDenCo
  • 1772 Answers
SOURCE: Maytag Gas Range With Touch Control Model: CRG9800C,
Sorry to read about your problem, I hope this helps you out.
You could have 3 different problems.
1. defective gas control valve to the oven
2. defective temp probe
3. defective gas control knob
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Maytag gas range oven wont cycle
it could be the thermocouple . or thermostat .
Feb 09, 2016 | Maytag 30" Free Standing Gas Range -...
Gas owen overcooks
I get this service call a lot so lets verify temp before we discuss possible causes set the rack in the middle of the oven hang an oven thermometer in the center of rack set a 350 let run 1 hour check the temp after an hour this gives the oven enough time to cycle and stabilize this will give you the true average of oven, temp placement of thermometer is important plus or minus 15F on either side of 350 is not that much of a big deal the max range for a temperature offset is usually 30F, there should be a tech sheet in a plastic pouch on the back of the unit now if you do find it to be running 50F too hot well there are test to determine if the temperature sensor is operating correctly it should read appx. 1654 ohms at 350 this tells the control board to open the heat relay stopping power to the gas valve lot of work you have to have the oven out back panel off to access the wiring going to control unplug machine at 350 disconnect wiring from board to ohm out sensor, sensors go bad and so do boards, sensor is cheaper try changing it first.
Apr 04, 2015 | Maytag Kitchen Ranges
I just install hot point gas range in my kitchen and the range oven and burners flame fail to increase as I turn up the the knob. Also the oven does not get very hot, the temp may be about 300 to 350...
you may have a defective gas flow regulator
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hotpoint Kitchen Ranges
I have a Maytag model MER5775QAW free standing range. When you press "bake" and then set the temp. and press "bake" again the numbers instantly climb to the set temp and the buzzer beeps showing oven at...
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
Nov 09, 2009 | Maytag MER5775Q Electric Kitchen Range
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
Oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Mar 19, 2009 | Maytag MER5770 Electric Kitchen Range
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven temp
after youve cooked at desired temp(400) for allotted time. turn off oven, and restart at 350. it wont start up right away( its already at 400, but it wool drop in temp and cook at 350. good cookin to ya!!!
Mar 23, 2008 | Amana ARGS7650SS Gas Kitchen Range
Maytag 30" Self-Cleaning Slide-In Gas Range - Stainless-Steel Logo
100 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
