Question about ViewSonic VG710b 17" Flat Panel LCD Monitor
My monitor goes dark after 1 second and won't come back until cycled off and on again
  • 1 more comment
  • manager76868 Feb 10, 2013
    Made by edwin chen alas monitors
    I am embarrassed of edwin chen alas. He did'nt fix it.
    edwin chen alas is dead in gvision.
    President:
  • 1,561 Answers
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a second, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on May 07, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
Uninstall the display driver from the device manager // restart the computer and that should work for you/
going to device manager?
xp comp: right click on computer/propertice/hardware/device manager/
vista comp: type device in start search box when u click on start button / select device manager/ click on the + sign of display adaptor , right click and uninstall,
restart the computer to install the driver automatically.
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
The screen goes dark. When U cycle the power switch off then on again the screen display returns for about 1 second then goes dark again. I would appreciate suggestions on what to do.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Our monitor just recently stop working correct. It is on fine during boot but once Windows starts up, the screen goes dark after about 2 seconds. If you turn it off and back on, we get a screen again for...
try reinstalling the os.
there might be file corrupted in the system folder,,,
since the monitor runs on start up , we cannot say that it has a hardware defect...
reinstalling or upgrading your windows will help..
Mar 11, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
My monitor only comes on for a few seconds and then goes very very dark, although the content is still there somewhere. But here's where I differ from the majority, if I can get to run System restore, the...
You need to verify if it's the monitor or computer--if possible, change out the monitor with a known-good one and see if the problem still exists. If it does, then it's a problem with the video card or driver software--if it doesn't and the monitor is an LCD display, then you probably have a failing power supply or display. In an LCD monitor, there are thin, bright fluorescent tubes which give back lighting to your image. A classic symptom of the screen going dark(with the image still visible using a bright flashlight), is the power supply that feeds the tubes or the tubes themselves. If the display is not under warranty, keep "new monitor" in the back of your mind because the cost of getting the unit fixed(if it can be done) rivals the price of a new one.--Hope I was of assistance--Rick
Sep 22, 2009 | Computers & Internet
Monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Oct 25, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor is on, goes light to dark in 1 second
I have the same problem with my Dell 17" monitor. I've been reading and what others with similar problems say is that the power supply has a bad capacitor.
Aug 08, 2007 | ViewSonic VE155b 15" LCD Monitor
ViewSonic VG710b 17" Flat Panel LCD Monitor Logo
217 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
