Question about Husqvarna Sewing Machines
Remove needle i have a huskylock 535D. how do i remove the needle to change it? do i need some kind of tool?
  • 135 Answers
Yes, a screwdrive that came in the tool kit.
Posted on Jun 24, 2010
I need to buy some needles for my huskylock 535D I live in Geraldton and have not been able to sorce them thought maybe I can buy some over the net or through an agent in Perth
I have been surfing the net and every where the husklock comes up it is attached to husqvarna
I suggest that you take the needle into a sewing machine shop and see if there is a needle the same as it basically there are several needle suppliers that cover all makes of machines
If you have a spotlight there then talk with the sewing section
Jun 18, 2015 | Sewing Machines
I need the set screw for my 535D Huskylock serger sewing machine
Need to replace the whole block....
Huskylock Dealer will advise
Mar 16, 2014 | Sewing Machines
535d huskylock serger parts
try calling a sewing machine repair shop and see if they have any
Oct 19, 2013 | Sewing Machines
Huskylock 535d
You may need to take it for service. However, since it is an older machine, it may be difficult or impossible to repair.
Oct 31, 2017 | Sewing Machines
Where can I buy the tool to change the needle in the huskylock 910?
try a screw driver that you use on eye glasses and see if that will
work.
Nov 06, 2012 | Husqvarna Huskylock Computerized 910
What tool do you use to change the needle on a husqvarna huskylock 910
Most sergers/overlockers will come with a tool kit including a small flat blade screw driver and a set of tweezers. Both are needed to change a needle along with a steady hand and glasses in my case.
Turn the flywheel towards you until the needle bar is at highest point. If you can, swing the pressure foot out of the way or remove it. Ditto the upper blade, if you can swing it up and out of the way to give yourself plenty of clearance.
Then using your small screwdriver, gently turn the needle screw a half turn at a time until the needle is loose and drops out. NEVER undo the screw all the way out, just enough to get the new needle back in.
Most needle bars will hold two needles with two screws so getting both changed is a bit of a fiddle, I usually slide the new needle up into the slot, then hold it up into the housing with my tweezers while I tighten up the screwdriver. Or I'll hold the tip of the needle up in place using a long fingernail while doing up the screw. YOu may find you need to slightly undo the left needle screw in order to replace the right needle as the two needles sit alongside eachother in the housing very closely.
On most sergers the two needles sit at different heights so have a good look before you remove and then make sure you get the new needle back up into the housing all the way. Always test by winding through a stitch manually just to make sure the needle is clearing your loopers afterwards.
Aug 02, 2011 | Husqvarna Huskylock Computerized 910
Need Huskylock 535D all purpose need plate
The parts catalogs show this part as obsolete.
Try Googling the top Husqvarna Viking dealers to find one with spare parts from junker machines. Most dealers have a good supply of used plates.
Jul 23, 2009 | Husqvarna Husky 165
Timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
Feb 07, 2009 | Husqvarna Husky 165
Sewing Machines Logo
155 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
