Question about Xerox One Touch 2400 Flatbed Scanner
Xerox scanner I have a xerox one touch 2400 scanner which worked perfectly with XP, but won't install with Vista. Can I download a driver to work with vista?
  • 74 Answers
You can downlaod them here - click on Windows Vista and youre done!
Posted on Mar 27, 2008
SOURCE:
I can't install xerox 2400 one touch scanner in windows 7
You need to use the Windows Vista driver. I used the 32 bit. Here is the link for the driver.
Hope this helps.
http://www.xeroxscanners.com/en/uk/products/X2400/drivers.asp
Jul 22, 2011 | Xerox One Touch 2400 Flatbed Scanner
Installed 2400 one touch scanner from disks supplied. My computer tells me it cannot find the hardware when I ask it to scan. I am running windows 7.
You need to go to the vendor's site and find the Windows 7 driver for this device.
If it isn't brand new, they may not have a driver yet.
It will work with Vista and XP but not Win 7 unless you update drivers.
Jan 08, 2011 | Xerox Office Equipment & Supplies
I've just bought the xerox 2400 scanner off someone, but it doesn't have any instructions. Is it just a case of plugging it in, and scanning?
The drivers for this scanner from Windows Vista down through Win98 are here: http://www.xeroxscanners.com/en/uk/products/X2400/drivers.asp You can also order a replacement CD with the OEM PaperPort software that came with the scanner.
You must install the software for the listed OSes before trying to connect the scanner to the computer. I can't find this scanner in the Microsoft Compatability Center listing for Win7 Compatability. If you have Win7, try plug and play (sometimes the generic driver will work but you may lose the front panel buttons on the scanner). Alternatively try the Vista drivers. (Uninstall any driver that doesn't work before trying the other.)
I hope this helps.
Apr 12, 2010 | Xerox One Touch 2400 Flatbed Scanner
I hae a memorex 6142u w/ no vista drivers???
Go to site http://support.visioneer.com/products/home/EOL/Memorex/
Download/save application file 6142. Check file properties, under compatibility select "run this program..." and choose Windows XP(Service Pack 2). if u do not have a vista option
Then run the program.
Good Luck
Jan 26, 2009 | Memorex MEM48U Flatbed Scanner
I dont have a driver
You can find the Vista drivers at this link:
I had no problem accessing the website. If you do, you can try to find the XP drivers on Drivers.com
You can try this to install XP drivers on vista systems.
Follow the instruction on this website on how to install XP drivers on a vista system
http://www.davesdrivers.com/forum/showthread.php?tid=2
Good luck and let me know,
Angela
Aug 03, 2008 | Xerox One Touch 2400 Flatbed Scanner
Can`t open driver file...
Hello sir,
i am format the c: drive and also instal to windowprofessione2. Then after to local drivers are not open properly. thet means(D:,E:,f:) the drivers are change to file. Then ask to supporting programs.
Mar 03, 2008 | Xerox One Touch 2400 Flatbed Scanner
Xerox 2400 Driver
you are using the right software or the operatuing system is not compatible with the software
Mar 02, 2008 | Xerox One Touch 2400 Flatbed Scanner
Xerox One Touch 2400 Flatbed scanner drivers
http://www.xeroxscanners.com/en/uk/products/OT2400/drivers.asp
will get you drivers and manuals in pdf fomat. I had same problem and works fine now. Good luck.
Dec 15, 2007 | Xerox One Touch 2400 Flatbed Scanner
I have the same problem, starting ten minutes ago. Keep in touch if you find the solution and I will do likewise
Regards
Steve
Xerox One Touch 2400 Flatbed Scanner Logo
157 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
