Question about Porter Cable 2" Flooring Cleat Nailer FCN200
What gauge is this gun? - Porter Cable 2" Flooring Cleat Nailer FCN200
    President:
  • 1,335 Answers
The L-nails are 16 guage. The FCN200 uses up to 2-inch L-nails.
Posted on May 07, 2010
I have h&r 20 gauge pump shot gun 1871 wanting to know if there is a slugbarrel for it
H&R Pardner® Pump - H&R 1871
www.hr1871.com/firearms/shotguns/pardnerpump.asp
  1. Cached
  2. Similar
This extremely versatile shotgun has an American walnut stock, ventilated recoil pad, chrome-plated ... 20 Gauge (NP1-206) Order Online From Gallery of Guns.
There are various barrel options including slug barrels.
20 gauge pump shot gun 1871 Google Search
Oct 30, 2016 | Optics
Need wiring diagram or schematic of the primary, secondary, and lighting windings or a weller soldering gun. even arough drawing of the windings that's close would work
You know that's a bit goofy, right? Only the manufacturer would have such information.
If you are serious, you CAN do it. Begin with an accurate Ohmmeter to measure the primary and secondary winding resistances on a new gun (at Sears, say.) To do that, measure the new gun's primary resistance at the plug with the trigger pulled, of course. Remove the gun's soldering tip and measure the resistance of the secondary without the tip and any incandescent bulb in place. (No need to pull the trigger.)
Hopefully you have some of the burned wire from the old gun. Measure the diameters of samples of the burned primary (thin) and secondary (thick) wires with a micrometer. With that information, look up wire gauge information online. You may need 24 gauge and 18 gauge enamel coated wire, for example. Note: a burned wire will no longer have its enamel coating so take that into account when determining the gauge of the "new" wire.
Note the "Ohms/foot" specification for each wire gauge. Divide that number into the resistance values you measured on the new gun (at Sears...). That will indicate the number of feet of each gauge of wire you will need to rewind the core!
Now I'm off to build my own refrigerator... NOT!
Feb 11, 2015 | Cars & Trucks
I have a 18 gauge 2" brad gun when you plug the
Increase air pressure.... you're way too low......
Dec 02, 2010 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
What is the angle of the 15 gauge nails for this gun and what nails are compatable
You did not mention the brand or model of your gun, however, you can determine the angle needed by placing a straight edge in line with the path of the driver and measure the angle from this edge to rails.. If the straight edge to the rails measure 90 degrees or makes a right angle, you need "0 degree" nails, if it measures 80 degrees, you need "15 degree" etc. Most generic nials 15 gauge nails will work. No need to by branded nails unless your gun requires an unusual angle. Good luck.
Jul 31, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
With the finish pro 35 can you use any 15 gauge strip of nails,glued or plastic strip
i believe that gun takes 16 gauge nails, and yes, all 16 gauge nails are the same, as long as they are strait, not angled
Mar 21, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
My gun fires 2 2in brads at the same time. Is there a fix for this?
most likly using wrong gauge brads check on gun for gauge size example 16mm 18mm ect.
May 10, 2009 | Stanley Bostitch BT200K
Need to know the brand of nails that work with this nailer
brand does'nt matter its the lenght and more inportant is the gauge if its shooting two nails than you are most likely using the wrong gauge example of gauges:16mm 18 mm ect. look on gun it should specify which gauge to use
Apr 30, 2009 | Tools & Hardware - Others
Porter Cable 2" Flooring Cleat Nailer FCN200 Logo
108 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
