Question about Homelite ZR10926 16 Chain Saw
How to stART HOMELITE 18 INCH TIMBERLINE - Homelite ZR10926 16 Chain Saw
    Brigadier General:
  • 4,088 Answers
Make sure you have fresh fuel mix in the tank. Pump the primer bulb about 6 times or less until the bulb draws fuel into it. This fills the carburetor with fuel. Close the choke and set the fast idle if the throttle trigger has a button near it--otherwise, operating the choke auto-sets the fast idle. Don't operate the throttle again until the engine is running. Turn on the ignition switch and pull the engine through smartly. It should start within several pulls. If nothing happens, then get back to us for some troubleshooting help. Hope this gets it running!
Posted on May 07, 2010
Races at idle
If the idle cannot be controled by the idle screw ( screw marked with an I or T on the side of the carb ) then you may well have an air leak through a crank seal or a gasket.
Nov 23, 2012 | Homelite UT10580 18-Inch Gas 42cc Chain...
Timberline Knives Kommer Canoe Hatchet where can I buy in uk
I do not know where you can get this, but I always question a desire to use a hatchet on the trail. A small folding saw can do almost all of the same jobs, and is much lighter to carry and much safer to use. If you really need to split larger wood, then a small axe is way way better than a hatchet. When I need one, I take a 2.25 to 2.5 pound axe on a 26-28-inch handle. It can do everything a small hatchet can do and weighs only a few ounces more, while it can also do the work of a full-size axe if I really need it.
SAFETY: A sharp axe is much safer than a dull one because it will cut with less force, and will cut into the wood where and not bounce off.
Dec 19, 2010 | Timberline Knives Kommer Canoe Hatchet
I need to know the amount of oil to mix with one gallon of gas for 18 inch homelite chain saw
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
Sep 09, 2010 | Homelite Garden
Timberman 45 w/18 inch blade No owners manual Chain on in grooves and sprockets. Nuts tight Just a little loose. How do I Tighten chain?
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
You can request a new OM and while at it an IPL here:
https://register.homelite.com/contact_us/new
Please do.
Lou
Apr 14, 2010 | Homelite Garden
How to change the oil pump on the chainsaw model pcn 4545
Patrick;
I could not find anything matching the number you provided. I did find an electric saw "RY43006 Chain Saw" here (follow the instructions):
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
I think with the IPL as a disassembly guide replacement is pretty easy. There are a couple of hoses listed, I suspect one of them failed rather than the pump.
If this is not your saw please provide some different numbers (reply below) and I will try again. Good Luck. HTH
Lou
Feb 25, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi Elec Chain Saw ECS-2040
The number you provided don't cross to an exploded parts list.
The drawing can be found here:
Homelite/Ryobi.com
I advise you find an authorized repair facility for your own safety. HTH
Lou
Jun 23, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a homelite 240-hg I cant get it started i
Try some starter fluid (eather) that wil give you an indication if it's ignition or a fuel problem.
Feb 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite ZR10926 16 Chain Saw Logo
162 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
