Just wanted to know if there was a way to have the audio output come from the JVC 460W MX-GC5 speakers instead of my tv?
    Novelist:
  • 100 Answers
If I was reading right there should be an auxillary input in the front if not the back of the stereo. If your TV has matching connectors just run RCA cables from the back of your TV into the AUX. Then your TV might have a menu where you can turn the internal speakers off. I know mine does and mine is very out dated. I hope this helped.
-Andrew Hawkins
Posted on Mar 27, 2008
Front faceplate/grille lights go on and off on their own..unit works perfectly otherwise JVC MX-GC5
Sounds like the unit is in 'demo' mode. Should be a button on the remote to turn this off.
Feb 22, 2013 | JVC MX-GC5 CD Shelf System
Jvc home component mx-kb30 protect mode on
First check that the speaker wires are not shorting, if okay! the problem is in the audio output stage of the receiver, the protect mode comes on if a load is detected.
Apr 25, 2012 | JVC MX-KB30 300W Mini Home Audio System...
JVC TH-V70 Shuts Down
Hello
Even after disconnecting the speakers, the systems shut down, means that there is something short inside the set. Normally, the output amplifier section circuits will have the short. The set need service, and may have to replace the audio output IC of audio secion. Contact the nearest JVC authorised service center at your town. OK.
Jan 24, 2012 | JVC MX-GC5 CD Shelf System
Just say protect and turn off, how can i cancel this
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Mar 29, 2011 | JVC MX-GC5 CD Shelf System
My JVC mx-gc5 stereo says protect and then shuts off
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Dec 12, 2009 | JVC MX-GC5 CD Shelf System
Displays "Protect" on screen
the audio amplifier output are fried
Dec 03, 2008 | JVC MX-KB30 CD Shelf System
My compact component system mx-gc5 keeps turning it self off after u turn it on. it stays on for like 10 sec
This is probably a fault on the power supply sometimes caused by a diode. If you are capable investigate but if not PLEASE dont try anything to put your life in danger as the voltages present in the stereo can easily kill or injure. Good luck.
Sep 26, 2008 | JVC MX-GC5 CD Shelf System
Jvc mx-gc5
Yep, as I suspected, the STK412-430 needs to be replaced. That is the most common failure part. Try replacing that and your problem should be resolved.
Dan
Sep 08, 2008 | JVC MX-GC5 CD Shelf System
Protect problem
I'm not really familiar with your specific model, so I don't know what the output stage looks like. I'd guess that this unit has a large black 'amp-pac" for the amplifier section. This should be attached to a heat sink in the rear of the unit. Look to see what the markings are on that part. I expect to see STKxxx. Can you post that here?
Thanks,
Dan
Black and White video output
check your tv system,(PAL,NTSC etc.)same as your cd player,go to MENU and select both to ,AUTO.
Feb 05, 2007 | JVC MX-J900 CD Shelf System
35 people viewed this question
 Grubhead
Grubhead
