Question about Telrad Executive Large Display ( 79-100-0000, TELDIG791000000LD ) Phone
How do I change the extension name from Telrad Console?
Changing names on phone
I have the software console on my desktop. open, go to LAN tab (need pswd) click connect, go to extension tab, press 4, then 1, then 1, then enter. Should see list of names and their ext #'s. make changes as you see fit. remember to press Apply for changes to take place.
Apr 04, 2014 | Panasonic KX T7436 Corded Phone KX-T7436
Change the extension name? For examlple change from 109 to 122
Is that a name or a number?
Extension numbering and name are in system programming and that's a function of whatever system you have, not the phone. Generally, it's in system program 003 and 004 for number and name respectively.
In number change, most Pana systems require you to change one extension to a number not being used. In a TA-x24, the numbers are still assigned in software to 124, so you would change 109 to something out of the universe like 133, then change 122 to 109 and 133 to 122 :-)
If you have voice mail you may have to manually assign it via the owner's mailbox 999 or from the maintenance console or hyperterm.
Carl
Oct 21, 2010 | Panasonic KX-T7730 Corded Phone
Hi I am trying to switch my old Telrad Digital phone to this one. When i plug it in, it askes for the DN #. Which I then put in the DN number. It goes through but then another message comes up that says...
This means that you have the wrong type of phone connected. The BA2 is a non-display basic phone. You are trying to plug in a different type of Telrad phone. Find out the type that you have and change the programming for your extension to match.
Sep 15, 2010 | Telrad SPL Dynamics Display Phone (...
Describe your Avanti 3015 caller id issue Problem One 3015 in the office has no caller ID, inside eManager the Caller ID is on? Any ideas?
I have an Avanti 3015D Telrad Connegy phone and initially I had a "Prompt" number 124 and was told to use that when changing my MAIN greeting. Now the prompt has been deleted somehow and I cannot change my MAIN greeting (not personal greeting)...How do I get the system to "prompt" me again to enter the 124 so I can change the Main Greeting (and I'm not talking about "enter mailbox or password either....). Please help!
Apr 20, 2010 | Telrad Avanti 3015DF Corded Phone
How do I change the name display on the MLX-28D?
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Jan 07, 2010 | Lucent Legend MLX-28D Corded Phone
How do I change the name that comes up on screen for a given extension?
To administer Labels for Extensions from the System Programming console2.gif:
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
  14. Press Home or Exit to exit programming2.gif mode.
Oct 02, 2009 | Avaya MLX 5D Corded Phone
I need to know how to change the names on the extensions
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Sep 10, 2009 | Avaya 4424D Corded Phone
Need to change extension names on a MLX-20l phone
http://dstech1.com/changing-the-name-on-an-extension/
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Jan 13, 2009 | Lucent Merlin Legend MLX-10D Phone
Lucent MLX-20L Extension Edit
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Telrad ICMR application manual
I called a phone company that deals with Telrad systems. They were able to walk me thru it.
The specific issue i was dealing with was changing the auto attendant hours. Once i tried the default password of 0000, i was able to use the Telrad IVM application successfully.
Apr 01, 2008 | Telrad Lands Phones
Telrad Executive Large Display ( 79-100-0000, TELDIG791000000LD ) Phone Logo
271 people viewed this question
Top Telrad Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Telrad Lands Phone Expert? Answer questions, earn points and help others
