Question about IBM ThinkPad T41 2373 Notebook
IBM r41 thinkpad makes one long beep and two short beeps when starting but the computer then stops and only the power light and the light to the left stay on
  • 20 Answers
There seems to be a slight problem here as there is no R 41. There is a G41 and a T41. They both have the same beep code and symptom. One long and two short is:
1. System board
2. LCD assembly
3. Dimm
If you copy and paste this link it will take you to the support page for think pads. Use the complete model number on the bottom of your machine and select users guides and manuals and you'll be able to download a copy of the HMM (hardware maintenance manual) used by IBM techs.
Posted on May 11, 2010
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Lenevo t61 1 long beep and 2 short beeo no display
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Nov 09, 2012 | Lenovo ThinkPad T61 6457 Notebook
Thinkpad X41 starting two short beeps, fan error and shuts of
The IBM POST code states that after the 2 beeps the screen displays the error.
In the case you have a faulty fan and it needs to be replaced.
Sep 19, 2012 | IBM ThinkPad X41 Notebook
My ibm thinkpad won't turn on
Try powering on laptop what happens do you hear any beeps or see any lights normally if u see lights this is a sign that it is working if not your motherboard could be bad if you see lights and hear constant short beeps this means your memory can be bad, Try powering on laptop without battery and only power supply plugged in.
Sep 05, 2011 | IBM ThinkPad T30 2366 Notebook
R52 thinkpad not boooting. making beep sounds on start up.
Welcome to Fixya
Beeping sound is telling you there is something wrong with the hardware. Different beeps has different meaning. Please refer to this link for the standard beep codes of your computer.
Hope this helps.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 26, 2011 | IBM ThinkPad R52 Notebook
Machine will not boot-up.....beeps 3-3-1.....please shed some light on the subject
do you know the make and version of your BIOS?
  • 1 long and 1 short beep = bad motherboard
  • 1 short and nothing else happens= disk drive/video related problem.
  • 1 long and to short beeps = bad video card
  • 1 continuous beep or non-stop short beeps= bad power supply
  • 3 short beeps = bad memory
if you can tell what you are trying to do i may be able to help further.
Oct 08, 2010 | IBM ThinkPad A21m 2628 Notebook
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
Won't start up
Hi there.
If the beep is a short beep then there is nothing wrong with the PC, just enter the bios utility, set the date and time, save the changes and exit the bios.
The computer will restart and should boot straight through to windows.
Please post back if you need anymore help or advice.
Good luck and thanks for using FixYa!!
May 24, 2009 | IBM ThinkPad T21 Notebook
Ibm thinkpad a22m turns on, but no screen
diid u change memory or something it means that some hardware is not compatible or broken lik memory mostly it because of that
Feb 13, 2009 | IBM ThinkPad A21m 2628 Notebook
Laptop problem
1 long beep + 2 short beeps during a POST (Power-On Self Test) for a IBM ThinkPad stands for System board, video adapter or LCD assembly failure.
Dec 27, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T41 2373 Notebook Logo
723 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
