Question about Vizio Gallevia GV42LF 42 in. LCD Television
LCD tv gets pink/blue lines, makes LOUD buzzing noise
Very intermittent problem: TV makes a VERY loud buzzing noise, and blue and pink vertical lines take over the LCD screen. Can't operate tv controls or even turn it off at first; but after a few tries, I can turn the tv off. When I turn it back on in a few seconds, it's completely fine again! (Westinghouse brand)
It's been happening very intermittently for a few months.
Thanks in advance!
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
  • 92 Answers
SOURCE: Vizio GV47L not turning on after a pop noise
check your power board, most likely that's the part that is causing the problem.
Posted on Feb 09, 2009
Highdefjeff
  • 124 Answers
SOURCE: Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Posted on Mar 03, 2009
  • 63 Answers
SOURCE: LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Posted on Aug 19, 2009
  • 101 Answers
SOURCE: 47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Posted on Apr 28, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
My LCD TV's audio is making a loud intermittent static buzzing noise.
A test you can make is remove most of the gear that is connected and start with just the cable and no box connected--run to see if issue happens-
Add more equipment until issue appears again--try this way to see what unit is causing this---if nothing but a DVD connected and it does it--its in the set--if not a time consuming thing but only way to see which piece of the equipment involved is the problem.
Jun 11, 2012 | LG 47LG50 47 in. LCD HDTV
JVC TV LCD Model LT-42PM30 intermittant buzzing noise
Most likely suspect is the power supply board---transformers on that board can and do vibrate hard enough to cause this.
At our shop we either locate the part creating the sound and treat it to hot blue to muffle and remove the noise or if confirmed to be on power board--REPLACE THAT BOARD.
Apr 29, 2012 | Televison & Video
It has a loud buzzing noise how do I fix that problem?
It appears that your connections are not correct. Please switch off the TV. Disconnect all the cable. Wait for some time. Reconnect cables one by making sure you strictly follow the color code i.e. that red pin cable must go in the red socket. After all the cables are connected switch on the TV. Loud buzzing noise is due to wrong connection of cables especially the Earthing/Neutral
Apr 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
188 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
