Question about Nokia N70 Cellular Phone
Don't receive network signal on my phone but it
Don't receive network signal on my n70. The network bars are all gone. I cannot make or receive calls though it recognizes any inserted simcard like MTN or Zain. I feel the phones inbuilt antenna used for signal reception has been damaged. Please help me, thanks.
    Problem Solver:
  • 6 Answers
Ask for a exchange from the shop you bought it or go to the shop you bought it at and ask for help.
Posted on May 07, 2010
Caller says my phone rings 2 x's and then the busy signal. I don't know how to fix this.
For purposes of discussion, lets say you are the caller. The "busy" signal may be a "reorder" signal. A reorder signal indicates that that the network inbetween your network and the recipient's network (or just the recipient's network) can not "find" a route back to your network. If you had received a busy signal, you reached the recipient's network but the recipient was on another call. If the problem is a "trunk" failure, the solution is beyond your reach. If it is a line failure, a call to the phone compan
Aug 07, 2017 | Lands Phones
Why can't I receive calls?
Make sure you have a signal bars on your device. You can trouble shoot your device by removing the battery and the simcard or you can try to select network operators. If doesn't work check your call settings maybe incoming calls enabled barring.
Aug 01, 2014 | Cell Phones
NOKIA N70 no network signal
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Oct 25, 2012 | Nokia N70 Cellular Phone
Call barring has been activated i dont know what is the barring password
Call Barring is a network feature. The Password for this feature is set by network. So don't need to worry. Just call your Network Service providers and ask them for the code, they will first authenticate you and will give you your code in return.
Note: Don't get spammed by someone telling you he can give you the code.
Regards, Wiqi
Aug 11, 2011 | Nokia 1100
My N70 when im calling is always in 'network busy',while compere to other cellphone they can easily call.pls help me. thanks.
Try to check your network signal if it's stable or dropping,also try to transfer your simcard to other phone and see if the problem is still the same.try check the settings of your network if you are using 3g or dual mode or only gsm mode,sometimes dual mode signal is not consistent by going to settings > phone > network and set it to gsm mode.
another way is formatting or resetting your phone,back up all necessary data first before proceeding,on your home screen type *#7370#, a lock code will be ask.enter the desire code or 12345 as the default code,then it will reboot automatically.Now try the signal if its ok.
If the above method doesn't work,might be a hardware problem and let a mobile service technician fix this problem,so you can find out what particular problem takes place.
Thank you for visiting Fixya,
Jul 12, 2011 | Nokia N70 Cellular Phone
MY PHONE HAS BEEN SHOW ON SCREEN OFFLINE . MY CELLPHONE CANT ACCEPT ANY SIM CARD SO DO NEEDFUL
Here are the following guidelines.
1. Insert your sim on your mobile, try to go to your profile and choose general then wait until the signal and network will comes out.
2. Try to check your simcard socket pins if its clean and align,as well as clean the simcard using an eraser from pencil or any.
3. this will turn into a hardware fixing cause might the simcard ic is damage or connected parts related to simcard reader,and with this,you need to visit a mobile service shop near you.
good luck.
Jun 21, 2011 | Nokia N70 Cellular Phone
I am using nokia 2600 and i want to activate call barring service but i don't know the barring password, I want the password.
Call barring is a service provided by the network/provider and you can only use it if your service provider supports it, Call them and if they were allowing people to use it, you will receive the PIN2 code after the add the number to the list you want to block from calling you!
May 09, 2011 | Nokia 2600
I can not call neither receive and there is a tone
If you're a problem in making calls and you're hearing a beeping sound or tone then ill be advising you to please check the signal bars on your phone because it might be that you don't have a good reception that's why you cannot make a call. If you have signal bars but you cannot make a call then you can try rebooting the phone and you can do that by removing the battery while the phone is on and then wait for 15 seconds, after that reinsert the battery and turn on the phone again and then try to make a phone call. You can also check if your phone has enough balance to make a call.
THANKS!
Apr 20, 2011 | Cell Phones
Service not found- when i call any one
If you're a problem in making calls then ill be advising you to please check the signal bars on your phone because it might be that you don't have a good reception that's why you cannot make a call. If you have signal bars but you cannot make a call then you can try rebooting the phone and you can do that by removing the battery while the phone is on and then wait for 15 seconds, after that reinsert the battery and turn on the phone again and then try to make a phone call. You can also check if your phone has enough balance to make a call.And if you still problem then kindly contact your service provider because its a probable issue with the network or the number of people that you are calling.
Apr 17, 2011 | Cell Phones
I can switch on my phone but cannot dial anywhere. The range bar is showing nil. Please assist. I am not receiving calls either or cannot do anything from my phone
DEAR SIR...
THIS PROBLEM SHOWS THAT EITHER THE NETWORK IS NOT REACHABLE OR PROBLEM WITH YOUR MOBILE....
JUST GO TO UR MOBILE SETTINGS AND SCAN FOR NETWORK MANUALLY,IF YOU DON
Oct 05, 2010 | Cell Phones
Nokia N70 Cellular Phone Logo
119 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
