Question about Sony VAIO TR1MP Notebook
IS Toshiba mk6006gah HARD DRIVE COMPATIBLE WITH SONY VAIO
HI,
JUST WANNA KNOW THE 1.8" HARD DRIVE IS COMPATIBLE WITH MY SONY VAIO LAPTOP
PLEASE REPLY
THANKS
  • 242 Answers
I know someone that bought a toshiba mk6006gah for his sony vaio TR1 series, so i think it is. Just look at the harddisk the local shop took out for you. Somewhere on the disk is told wich size it is. You could also give me the typenumber of that disk. Then i could tell you the size for certain.
Posted on Mar 27, 2008
Pcg 61213w
if the sony laptop already has an OS on it or a newer version of windows than XP, you have to uninstall the current OS on the sony vaio. also, that means reformatting the Hard Drive on the sony which actually wipes it clean. Before you do that, you should have the original disk of the sony pc drivers installation or you need to go to the product(sony vaio) web site so you can download those drivers for (PCG-61213W) to disk or flash drive. after wiping Hard drive, you can install the XP, then the drivers that you downloaded. However, viaos are strange pc's so i would ask Sony if this XP install will be compatible with the Sony pc hardware components first. good luck.
Apr 30, 2014 | Microsoft Computers & Internet
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
How do I replace the hard drive in my js110j/s all -in- one????
hi
you may want to try this
http://www.ehow.co.uk/how_6899686_do-replace-viao-hard-drive_.html
usually any sata compatible mobile drive fits this and can be used to replace your old laptop hard drive. hope this helps.
please let me know
janc30
Feb 11, 2011 | Sony VAIO VGC-JS110J/S Notebook
Sony vaio laptop unable to detect new hard disk
Try connecting the drive to another pc with a usb adapter, create a partition and format it. Then put the drive back in the vaio and reinstall windows. This should fix the problem.
Aug 09, 2009 | Sony VAIO TR1MP Notebook
Recovery Error 320
I had error 305: 69 when I tried to repair my sony vgn-ns160d using the recovery disc1. I called sony support and they told me that me hard drive was defective and needed to be replaced. they did not want to send me new recovery discs beause I was out of warranty. I copied the recovery disc at slow speed on another computer and tried rebooting the sony laptop with my fresh copy of the recovery disc. and it WORKED! it was not my HD that was defective it was their recovery disc! sonys support is non existent! trying to sell me a new hard drive!
Jul 07, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Sony vaio laptop cannot boot
hi and hello their..last year i have the same problem like your`re with my client..my 1st see the problem about that error is memory i suggest my client to make replace the memory..i think this is way the best you do 1st.the processor of laptop cannot advice to replace only memory and Hard drive..Thanks and Good Luck..^_^..>GOD Bless you...
May 09, 2009 | Sony VAIO PCG-K33P Notebook
I wanna replace the hard drive in my sony vaio vgn-nr12oe laptop?
All you need to look for is a 2.5 inch SATA drive, such as any of the ones on http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010150380%201035915133%201035507777&name=5400%20RPM
Dec 23, 2008 | Sony VAIO VGN-NR120E/S Notebook
HARD DRIVE FAILURE
hi dear
just back up your harddrive in other computer just release first
oke
Mar 27, 2008 | Sony VAIO TR1MP Notebook
Sony VAIO TR1MP Notebook Logo
168 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
