Question about Garden
After starting the JD LX176(which starts right up) gas leeks out of the hose under the air filter. This has just happened after sitting for the winter. The gas was replaced with fresh fuel.
  • 143 Answers
I dont know what type of engine you have, but you must remove the carburettor and dismantle it . The problem could be with the fuel inlet needle valve which could be dirty and sticking or it might be the float. Wash the carb. with a clean brush and fuel. Sometimes the float becomes perforated and fills with fuel and weighs it down, so the carb. will overflow. Try this, it`s the best i can do. Stephen.
Posted on May 07, 2010
Having problems starting my 1985 yamaha maxim xj700 after it sits over night i have to crank it for like 5 min b4 it will even try to start the next time i feel it shouldnt take that long. Also once it...
ck the plugs they are prob filled with carbon , if so get the carbs adjusted and make sure after it starts for a few seconds you open that choke all the way so this does not happen ,ck the vacuum hoses if one has a pin hole in it it will run like crap like you are saying , this is the number one thing with bikes , the sit and have bad gas and it will run like crap or you have a vacuum problem or a gas problem or a bad air filter ,gas filter , it is always something stupid for the most part , you need gas ,air ,and spark , eveything else is set,
Aug 23, 2014 | Motorcycles
2003 2liter runs fine but it just quits after sitting still for a min or two but starts right back up
I would start with cleaning the idle air control, then would clean the mass air flow. Also check the air filter. I have ran into oil soaked air filters on the Focus.
Jun 27, 2014 | 2003 Ford Focus
1990 TOYOTA 22RE WONT START AFTER IT SITS ONCE IN A BLUE MOON WHEN I DO GET IT STARTED ACTS LIKE ITS FLOODED SKIPPING BLACK SMOKE THEN IT CLEARS UP. I HAVE NOTICED IT SEEMS TO BE RAINING WHEN THIS HAPPENS
Likely a fuel problem.
Replace the gas filter and air filter.
The gas filter should be under pressure from the fuel pump.
If the problem persists you may need a new fuel pump. This is usually located on top of the Fuel tank and it is hard to get to.
Mar 17, 2014 | Toyota Pickup Cars & Trucks
2005 Chevrolet Impala Gasoline smell, sometimes seems to come through heat vents
fuel pressure regulator ! $50.location/top right side engine.smells like gas in cab strong while parked with air /heat on . check this. mine started leeking gas after 60,000 miles. easy fix one star bolt/hose/gasket 15 minutes.
Oct 06, 2012 | 2005 Chevrolet Impala
The battery is not charging. As long as I have a hot battery in my JD lx176 it will start, but the battery discharge light stays on until battery drains.
Under dash on left side you will see the regulator tucked behind frame. Once located unplug white connector and check the Brown wire for any damage in or around connector. These will tend to melt or turn the area around the Brown wire black do to poor connection. If everything looks good there then replace regulator.
Jul 08, 2011 | Garden
Trouble Starting VESPA
Check for bad gas -- water in gas , it is likely you have left the choke on.
Jun 02, 2009 | Peg Perego Vespa Scooter
I have a 89 chevy 1500 4x4 with a power steering leek and can't see the line that is leeking because it is going throught the fram after leaving the gear box
A very Fast leak Is Simple to Diagnose
  1. Start Engine with reservoir Full
  2. Have a Helper to sit inside
  3. Go under vehicle and look where you suspect leak is
  4. Have helper turn steering wheel to
  5. RIGHT or LEFT All the way till it stops and hold it there
  6. If you see it Pouring out from the Area suspected.
  7. That WILL be the HIGH PRESSURE Power searing hose.
  8. Under High Demand they have lots of pressure.
The Low side (RETURN will leak ALL the TIME and just Drip unless there is a Large hole in it
Hope I Have Helped
Jan 16, 2009 | 1989 Chevrolet K1500
Tractor not starting , I do not see any gas in fuel filter
I would suspect the fuel pump. Those thin diaphragms wear out every few years. But you can also make sure there is no obstruction in the line from your tank at the same time!
Nov 11, 2008 | Garden
Difficulty starting
darn thing wouldnt start after I fueled it up. After sitting for 10 min it fires right up and runs great. When starting cold it fires right up with no prob. Someone told mevapor lock is my issue this sound right ? and if so what is vapor lock and how do I prevent it ? thx all for your support.,The vapor lock situation happened to me a few times with my 748, so it CAN happen. To test this theory, just fill your tank to 1/2 of what it normally holds, next time you fill it. Or pop the cap off right now and let it sit for 10 minutes and close it back up again. Al your doing is releasing the pressure on the system. Will this do any good? Well, had always been filling my tank too high and once I realized that popping the gas cap, would release the pressure, I never had a problem after.,,,
Nov 10, 2008 | 2002 Ducati 998 S
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
