Question about LG WM-2277HW Front Load Washer
I need to order the gasket or seal can't get anyone that knows how to get this I is the one that stops the water from coming out of the door
  • 64 Answers
Try this link www.partsstore.com or http://www.partstore.com/Search/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith.aspx?utm_source=v01-G-01&utm_medium=website&utm_campaign=Brand_landing_pages&s=google *Mark*
Posted on May 07, 2010
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
MIELE G646 Wonderful machine, but now 10 years old ! I noticed a small leak on the floor which appeared to be coming from the bottom of the door, on both sides. This was noticed after a programmed wash...
Clean gasket with clorox to remove any funk, and apply vasoline to gasket to improve seal. If you still have water leaking, you will need to replace the seal on the dishwasher. Should be able to order from an appliance parts dealer, or they may provide a univeral gasket that would fit your machine.
Jan 07, 2012 | Dishwashers
Water leaking in my 05 H2 Hummer and don't know where from....checked sun roof, rubber doors seal and still can't find problem what else can I look for....no not heater core either...
first is the water coming in while the a/c is running,because your evaporator might be clooged.if the passenger floor is wet thats a sign that it may be
Sep 20, 2010 | 2003 Hummer H2
We want to change timing belt in 87 acura 5 door intergra 1.6 and also replace all belts and water pump we do not know all parts to get could you give me a list? It has air conditioning too thank you for...
1) Belts: Timing belt, alternator belt, A/C belt, power steering belt.
2) Water pump and seal.
3) Timing belt tensioner- option.
4) Front crank oil seal-replace if oil is leaking.
5) Two camshaft seals-replace if oil is leaking.
6) Instruction on how to install the timing belt.
May 27, 2010 | 1987 Acura Integra
Whole in seal and a smell
Is the hole, or a tear? If its a hole, that's the normal hole to get the excess water out of the door gasket. If there is a tear, you'll need to replace the door gasket. The smell you get, is due to not leaving the door open, you'll need to leave this, and the dispencer open all the time, when your not washing. The unit needs to vent, in order not to have build-up of mildew/mold.
Mar 28, 2010 | Hotpoint Washing Machines
I noticed water on the floor (right corner) and my concern is that I have hardwood floors. It is not a lot that I can see but my concern is that water is leaking underneath where I can't see. It is 8yrs...
Are you sure the water is coming from underneath the dishwasher? From the symptoms you described, this sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. Some other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of about $130.
2. Replace the door seal at a cost of about $35-$40.
If the leak IS coming from underneath the dishwasher, you will need to remove the lower toe panel under the door and start the dishwasher to confirm wher eit may be coming from and at what point in the cycle it occurs (i.e., does it leak during the initial fill, during the wash cycle, or during the drain cycle). It will be much easier to determine a cause if you can narrow down the symptoms. Leaks under a dishwasher usually come from leaking hoses, or leaking grommets where the heating element is installed. In a worse case scenario, the tub could be cracked or have a hole melted through it (if plastic) from utensils that end up on the heating element during the drying cycle and heat up to melt the tub. You will need to do a thorough inspection and post back with the results, so that I may be able to advise you further if this is the case. If you need parts, they can be purchased from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
If the model number you have this listed under is correct, the part number for the door gasket is 902894. The part number for the inner door assembly is dependent upon your serial number.
I think I would pursue the cheaper option, first. Its also the much simpler option. Since your dishwasher is 8 years old, it is highly likely the door gasket is worn and needs to be replaced. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. NOTE: I personally own a Maytag model such as yours and experienced the same problem. Replacing the door gasket solved the problem for me. It may for you, too. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 30, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Retro-fit drain hose
hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Oct 22, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
82 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
