Question about Gestetner Copier
Where is the transfer belt assembly located and the the waste toner in a gestetner 4532?
  • 903 Answers
Hi, as you're looking at the front of the 4532, the transfer belt assembly is on the right side. Open the duplex door that hangs off the right side, and then open the right side cover on the copier. You will see a wide brown belt that sits on the door -- that unit is the transfer belt assembly. You can remove it by turning the plastic lever on the front side and lifting the unit off of the door.
The waste toner tank is contained within the transfer assembly. If you remove the transfer belt from the rest of the unit (it's only held in by clips and springs) you can pour the waste toner out by turning the unit upside down so the toner spills out past the cleaning blade. (Make sure you have a trash bag or other container for the toner to fall into.)
Posted on Jul 18, 2010
Where does oki c9500 waste toner box located
Your printer does not have a waste toner bottle. Waste toner is stored within the transfer belt. When full it will give you an error indicating its time for a new transfer belt.
Jul 08, 2017 | OKI Office Equipment & Supplies
Where is used toner bootle dsm 635
it has not waster toner bottle on the machine, the waster toner is being recycled in the photo-conductor unit (PCU) so if the machine show replace the waster toner bottle just clean the PCU of the machine on the drum upper area
Sep 21, 2015 | Gestetner 3532 4532 Dsm635 Dsm645 Toner 4...
How do i program user codes for the gestetner 4532sp?
user tools> system settings> address book mgt>new program> fill in the blanks.
Jul 24, 2013 | Gestetner 4235 4532sp 4245 4532 Sp Toner...
Can't find the toner waste bottle to empty it for Gestetner 4532. Where is it located?
It is located in the transfer belt assy.
open the right door look for the brown belt assy
lift lever and remove
remove front and rear springs
spread clips and swing belt assyup from case assy and remove
remove three blade screws remove blade and set aside
slowly dump waste toner
reverse procedure to reassemble message should clear (nothing to reset)
Good luck
Apr 14, 2010 | Gestetner Office Equipment & Supplies
WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
Unit is in the right side cover. New one should have instructions with it, but I think you unlock a handle and swap, then lock handle again.
Apr 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Where is the waste toner bottle for the Gestetner dsc 535
It is located on the lefthand side of the machine under the yellow pcu unit. You will have to remove a cover next to paper tray 1
Mar 16, 2010 | Gestetner Copier
The used toner bottle is full. Where is it
Open the right door,remove the transfre unit,remove the transfre belt unit.The waste toner collection bootle is located under transfer belt section.Remove 3 srews remove the case and use the vacuum cleaner to clean the waste toner empty.
Nov 24, 2009 | Ricoh Aficio 2035 Copier
My Gestetner 3235 will no longer work.
Open the duplexer, open right door the brown belt thing is the transfer and waste toner assy, on the front side of this is a 1.5 inch handle that needs to be lifted to the upright position and rock it away from the copier and place it on newspaper, take the 2 springs off lift the brown belt upper portion up releasing the tab on the front side. now you need to "dump" all the waste toner from the lower half. and reassemble, rember to put it back like it was.
-Carl, please let me know if this helps.
Jun 18, 2009 | Gestetner DSc224 Copier
Installing transfer unit
open the front and right door , remove the waste toner bottle . remove old and put new.
don't forget to unlock and then lock the waste toner bottle.
Apr 06, 2008 | Office Equipment & Supplies
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
64 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
