Question about Canon Laser Class 830i Plain Paper Fax
Canon 830i fax machine is sending blank pages - I believe the scanner is not working. Just received yesterday and believe it's an installation problem. How do I fix it?
JayBlair
  • 328 Answers
SOURCE: can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Posted on Aug 01, 2007
SOURCE: Copying and fax sending problem
NOT A SOLUTION BUT A QUESTION, MY CANON B820 IS NOT PICKING THE PAPER AND PLUS I CAN SEND BUT NOT RECIEVE OR COPY AS THE PAPER ZIGZAG MANNER. HELP!!!!!
Posted on Sep 22, 2008
  • 75 Answers
SOURCE: All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Posted on Jan 23, 2009
iservice
  • 318 Answers
SOURCE: we cannot receive faxes
Normaly this fax is set for auto receive off.Switch it to on by pressing on/off button once,less than a second.
Posted on May 15, 2009
brett207
  • 231 Answers
SOURCE: Our RX report for our Canon 830i fax machine lists
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Posted on Dec 16, 2009
Testimonial: "Thank you!"
Can't receive large faxes
This is not a UK model but the same principles apply. When you receive a fax it is stored in the memory until the whole page is received, then it will start to print. The memory is not split so if you have a lot of faxes to transmit stored in the memory, they will gobble up the memory and reduce the size for receptions to be stored in. Check to see what is stored and delete them to free up memory. If this does not resolve the issue then the machines memory will need to be cleared by the service mode. As I don't know the UK version I cant advise any further.
Mar 12, 2014 | Canon Laser Class 830i Plain Paper Fax
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
Fax comes out blank at the receiving fax machine.
This type of fax is "toy" buy a laser fax an get rid of all your problems
May 26, 2009 | Canon FAX-JX200
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Canon Laser Class 830i Plain Paper Fax Logo
70 people viewed this question
old marine
old marine
