Question about Samsung AS18A6RB Air Conditioner
THE CONDITION IS NOT RUNING E2 PROBLEM APPEARS.
E2 WHATS THE PROBLEM? HELLO SAMSUNG
  • 38 Answers
Pipe thermistor replace
Posted on May 07, 2010
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Apr 26, 2017 | Water Water Heaters
Just installed, shows error code E2, is not heating water
May 22, 2015 | Water Water Heaters
Samsung dms500tr comes up with e2 error there is water to the aqua valve
Hello Keith:
My name is Peter. I am a retired field service appliance technician.
You have a faulty fill hose and valve assembly.
Part Number 1673572 Cost: $136.00
It is located in the back of your dishwasher.
hwk1huedygosaaaaaelftksuqmcc
Dec 13, 2014 | Samsung Dishwashers
Samsung washer front load willnot rinse - no water coming out of hose to drain. E2 shows up
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
May 31, 2010 | Samsung WF337AA Front Load Washer
I get a message: E2. Whats that?
Hello :
Check for manual here please :
Samsung MW5592 Microeave Oven manual .
good luck .
rate please !
Mar 19, 2010 | Samsung MW5592W Microwave Oven
Hello, it seems my palm Tungsten E2 is not compatible with Windows 7 (hotsync). Anything I can do or is there another PDA that will work? Thanks, I do need the PDA.
you need to uninstall the version of palm desktop that you alredy have and install the 4.14 palm desktop, with the hotsync manager that 4.14 includes you should have no more problems
Feb 01, 2010 | Palm Tungsten E2 Handheld
Code e2 f3 appears, oven goes to self clean mode,
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&^%
Oct 12, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Dec 11, 2008 | Office Equipment & Supplies
Expansion card
Has this card worked before in your Palm?
Jun 30, 2008 | Palm Tungsten E2 Handheld
Not Cooling or freezing.
you need to clean the evaporator coil under bottom off refrigerator. and check in the back of refrigerato to see if fan is runing. I not you need a replace it sam
Sep 25, 2007 | Frigidaire FRS23R4A Side by Side...
Samsung AS18A6RB Air Conditioner Logo
407 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
