Question about Strait-Line Strait Line 6041706 Stud Finder 150' w/Tape
How do I know when i am on the stud - Strait-Line Strait Line 6041706 Stud Finder 150' w/Tape
    Brigadier General:
  • 4,088 Answers
These usually need to be calibrated in a stud-less section of the wall so that the LED just goes out. Slide the finder over the wall slowly until the light turns on--that is the first edge. Continue moving and the LED should go out--that is the second edge. These two points should be marked lightly with a pencil and the midpoint between the marks locates the center of the stud. Note that these tools will respond to wiring in the wall the same way. Hope this helps!
Posted on May 07, 2010
How to replace a broken stud on 99 pontiac sunfire
hub studs are just a press in fit . the replacement can usually be done with out the hub removal. remove the drum /disc rotor
using a hammer and punch drive the broken stud out. place new stud in position and pull in to place using nut and spacers to get it home .
if you can remove the hub and drive the broken stud out . fit new stud and place the hub over something like a piece of pipe /socket the new stud in the pipe or socket) that is on something solid and hammer the new stud home.
Dec 26, 2014 | 1999 Pontiac Sunfire
How to install a Crane Floating Glass Shelf?
Almost all measuring tapes have markings for the wall studs so once you've found one stud, placing one mark on the stud the next mark indicates the next stud.
Jul 19, 2014 | Spancraft Glass 12"" Floating Crane Shelf...
2006 dodge caravan with rear draum brakes. Broken wheel stud on right rear wheel. Got the drum off, got the broken stud off. but i cant get the new stud in. not enough space to get the new stud in. Is...
Make sure all tires are chalked,put vehicle in neutral,turn drum till it has a clear spot to knock stud out,use hammer and wooden block,don't use metal punch,can cause burr on end of stud and not want to come out of hole.Both tires on back may need lifted in air to turn.
Jul 05, 2017 | 2006 Dodge Grand Caravan
Broken wheel studs on a 1987 jeep wrangler
No need to replace the hub just the studs. The come in from the back and are splined to prevent the stud from turning with the nut. Remove the hub --drive out the broken studs and put the new ones in from the rear and drive them back in. Get the studs from the dealer spares or a good tyre retailer.
Apr 08, 2013 | 1987 Jeep Wrangler
How do you know when the strait line laser level and stud finder is on a stud
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
http://www.irwin.com/support-services/product-manuals
If this answer has helped, please rate it a four-thumbs up. Thank You.
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
Strait-line
Yes. The lights represents the stud. As you move it over each light lights up.
May 30, 2010 | Strait-Line Strait Line 6041706 Stud...
Need to know how to replace front studs
You might be able to get the studs out by removing the brake caliper and working thru that hole, if not you will have to remove the rotor. Working thru the caliper hole knock the studs out with a hammer, if you can get your hand or other tool in to remove the old stud, and insert the new one, use a nut of the proper thread, not the lug nut, to pull the stud into the rotor a little grease on the threads will be a big help here. Make sure the studs are fully seated by measuring the length of one of the old ones before you remove it and pull the new ones in untill the length matches. If you have to remove the rotor you will require a special tool to remove the locking nut from the rotor, but once the rotor is off use the same procedure to change the studs.
Apr 04, 2010 | 1986 Chevrolet S-10 Blazer
Have broken studs on the front passenger side and need to know how to replace.
I assume that you are referring to the wheel studs and if so you will have to remove the wheel, the brake caliper, the brake caliper stand and the brake rotor. Drive the old stud out with a hammer. Make sure you purchase new lug nuts with the studs. If they are the acorn style, buy one that is not to help with installation. Slide the new stud in the hole from the rear of the flange, install some washers for clearance of the stud shoulder. Install the non acorn style lug nut on the stud backwards. Using a impact gun, pull the stud through. Remove the backwards lug nut and washers.
Jul 26, 2009 | 1989 Nissan Maxima
Broken wheel stud.
Studs are pressed in. Heat the studs with a propane torch, and then use a ballpein hammer to pound them out. Insert new studs, and use nuts to draw them into place
May 11, 2009 | 1996 Pontiac Grand Am
Procedure for replacing broken rear wheel stud on 1988 dakota.
It is a Knockout Stud. It will take quite a bit of force to get it out to. The new stud just goes in the Same way. Use a little WD 40 on Install for easier insert. The Lug Nut will keep it from getting loose.
Jan 23, 2009 | 1988 Dodge Dakota
Strait-Line Strait Line 6041706  Stud Finder 150' w/Tape Logo
1,048 people viewed this question
Top Strait-Line Measuring Tools & Sensors Experts
Vuk B
Chris Delaney
Chris Delaney
Level 1 Expert
Are you a Strait-Line Measuring Tool and Sensor Expert? Answer questions, earn points and help others
