Question about Bosch Dishwashers
WATER NOT FILLING, WATER IN BASE OF MACHINE
WATER WILL NOT FILL. OHMED SOLENOID COIL GOT 970 OHMS. NO POWER TO COIL DURING CYCLE.
  • 269 Answers
Coil is ok.Is ithere water in base of dishwasher and is it trying to pump out then the antiflood switch is on and will not let in water,or a pressure switch problem or programmer fault.Hope this was helpful.
Good Luck
Posted on May 07, 2010
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Dishwasher not filling
The water float switch, located on the inside bottom of the machine, may be stuck in the up(off) position keeping the water valve from functioning. This is a safety device that turns the water valve off when the machine fills in order to keep it from overflowing.
The water inlet solenoid mounted on the inlet valve under the bottom front may also be malfunctioning not allowing the water valve to open and fill the machine. If electricity is present at the solenoid terminals when the machine is in fill cycle, then check the solenoid coil to see if it is open(no continuity). Also, the timer may not be calling for water/ sending voltage to the inlet valve solenoid.
I would start by manually operating the water float valve a few time to see if that helps. You should hear a microswitch click each time the valve stem is moved up or down by the float. If not, check to see if voltage is getting to the float switch and the water inlet valve solenoid.
Most(if not all) machines have a safety cutoff switch which activates when the door is opened. That switch could also be malfunctioning not allowing voltage to the water inlet valve solenoid in fill cycle.
Jan 26, 2012 | Meiko Dishwashers
My Kenmore washer will not shut off the hot water at the end of the fill cycle
Water valves work on a hydraulic principle, the surface area of the valve where the water comes to the valve is more than the opening that it passes into the machine.. The pressure of the water shuts off the valve. The electric solenoid opens the valve when power is applied to fill the machine.
If you unplug the washing machine while it is filling and it keeps filling you have a bad water valve.
If you unplug the machine while filling and it stops filling you have a electrical problem or a bad pressure switch.
Jan 09, 2010 | Kenmore Washing Machines
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Attempts to fill w/ water but won't...
you can check the inlet solenoid coil. maybe there is no power coming to the coils or if there is power, the coil is burnt.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Machine does not fill with water
I had a Zanussi d/w up until about 5 years ago and there were two perennial problems that required attention. First of all, there was a double solenoid inlet valve for the water supply at the back, one part was the main fill, the other was a supply to the water softener - big plastic lump in the bottom under the salt filler. The main fill solenoid would fail about every 2 years and I would buy a replacement directly from Zanussi for about £10. I believe the failure may have been due to the fact that the machine was filled from the hot supply. This was allowed in the specification but the higher temperature may have led to failure. (Side note) In any case, it is better to fill dishwashers with cold water anyway because during the initial part of the wash cycle proteins are rinsed off rather than being stuck on the items, and secondly, heating from cold increases the contact time of the wash detergent solution and also improves results. If the solenoid controlling the supply to the water softener has failed, it may well lead to the phenomenon you are seeing because the regeneration cycle happens after the wash in most machines. If you feel comfortable about using a mains tester(a neon screwdriver one would do) and can *safely* reach the solenoid with power on and the machine the right way up, then you could see whether power is reaching the regeneration side of the valve or not. If it is, and water is not entering then you have the culprit. Another area that affects filling is the level switch. Generally these are pneumatically operated device looking like a flat drum, about 8cm across and 1cm or so thick. They are generally mounted up high in the machine or door and have two or three wires on terminals and a small flexible plastic tube leading somewhere into the wet area of the machine. As the water level rises, water goes part way up the tube and air above it operates the switch to turn off the water. Sometimes there are two levels used and hence two switches inside this assembly working at different pressures. One could have gone. Another problem is that gunk can get in the lower part of the tube and reduce or block it from detecting. and generally this results in no filling at all. Hope this helps!
Mar 25, 2006 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
121 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
