Question about Panasonic Microwave Ovens
Clock control on NN-K657W panasonic microwave
MicrowaveSvc
  • 9047 Answers
SOURCE: PANASONIC INVERTER MODEL NN-S76OWF
While your exact model in not available for download, you should be able to find one close enough to work here:
http://panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=87
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
SOURCE: Panasonic NN-C994S stop 2 sec. after I press Start.
Sounds like the power inverter
Posted on Apr 18, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: i have a panasonic slimline combi NN A554W which
, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Posted on Oct 06, 2009
How do I set the clock on a Panasonic microwave nn-e271wm
To set the clock, you need to press Timer/Clock twice. Then press the 10 Min keypad several times until you get to the correct hour. Then press the 1 Min keypad as needed to get to the closest 10 minute period below the current time. Finally press the 10 Sec keypad several times to reach the current time. Then press Timer/Clock once to exit the time set feature.
Panasonic has the manual for the NN-E271WM on their downloads page: http://www.panasonic.eu/Downloads/en_GB/popup.html . Enter the model number and then click View. You will need to accept the Panasonic Terms Of Use and click View again. The direct link to the manual is currently http://tda.panasonic-europe-service.com/docs/2z5845f124z3z39cabz656ez706466z25z9709ff8b3ba329b0c218b9bf248a6442e93022b3/tsn3/data/ALL/NNE281BMBPQ/OI/912715/NN-E271WME281BME281MM.pdf . See page 21 in the manual (23 in the PDF) to see the procedure.
I hope this helps.
Dec 05, 2016 | Panasonic Microwave Ovens
How can I set the clock on my panasonic microwave nn-sn6715?
you will see on the controls a switch marked CLOCK, press this and the set the time using the number keys,
Aug 08, 2014 | Microwave Ovens
Panaonic nn 1000 gs 597 no working microwave
follow this steps and fix it. God bless you
No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models
Jan 23, 2013 | Panasonic NN-H965 Microwave Oven
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
I have a panasonic range microwave oven model NN-H264/S254 clock cannot be set. (It use to work but no longer can be set)
Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
I belive the information you seek is on page 12 of the manual.
Hope that helps...
Aug 13, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
