Question about Roper RAX4232KQ Top Load Washer
Roper won't drain
I have a roper washing machine that runs good thru the wash cycle and then just stops. What do I need to look at?
  • robcrawfordc May 07, 2010
    How do I test the timer?
    Is this a beltless model?
    Thanks
    How do I check the timer?
    What would cause the water not to drain, no noise?
  • Roper Master
  • 8,220 Answers
What I suspect is the lid switch. A lid switch is in there to keep people from being harmed during the spinout cycle. That is a direct dive washer. I have devoted a page on this model in my blog. The lidswitch connect from the harness features 3 wires. Two gray or HOT wires and one green or Ground wire. Jump the two HOT wires and the washer will run . You can operate the washer like this but it might be dangerous for children and stuff. This video shows how to replace the lidswitch
This one shows various models( they ain't all the same)
ROPER WASHER SERVICE MANUAL
Get yer Roper parts here cheap
Posted on May 07, 2010
  • 11,896 Answers
That could be a fw different things. A bad timer would cause it not to advance to the next cycle. If it doesn't drain, then a clogged drain or drain screen would be the cause.
  • Nate Stansfield
    Nate Stansfield May 07, 2010
    No noise and no drain would be bad timer, no power, or faulty door switch.
    If just no drain, I would say plugged drain or faulty pump.
    see here:http://www.acmehowto.com/howto/appliance...
    and/or here:
    http://home.howstuffworks.com/how-to-rep...
  • Nate Stansfield
    No belt on this one. It is direct drive. You can view entire parts diagram at
    http://www.partselect.com/MultiModels.as...
Roper washing machine whines intermittently throughout the entire wash, rinse and drain cycle.
Roper whining noise Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > whining noise > Washing Machines
Roper washing machines whining noise related questions and answers. Ask your Roper questions. Get free help from washing machine experts.
Sep 28, 2015 | Roper Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
WASHER WILL WASH ON ALL CYCLES, BUT WILL NOT DRAIN OR SPIN ON EITHER CYCLE
If the timer advances normally thru the spin and drain steps of the cycle you selected, than the problem that would cause neither spinning or draining, is the wash motor is not reversing. The motors is a two direction motor. It spins clockwise for normal agitation, but counterclockwise to engage the wash drum clutch and operate the drain pump. I would ask you to check for motor sounds at all during the spin and drain cycles. The pump reversing in the spin or drain cycles can be a function of the machine's lid safety switch, or if not the motor switch or timer contacts. The lid switch is first thing to check here, for sure! If the machine seems to stop running when it comes time to drain or spin, the lid switch is your best bet!
Hope this helps.
kcomp1863
Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
Hello my Roper washing machine is not switching
Check your lid switch. That is what controls the spin and drain cycle.
Eric
Jun 27, 2010 | Washing Machines
Have a whirlpool roper washing machine, runs thru cycle perfect but will not spin...lid sesor or switch was no good so took out and direct wired does that switch have to be there to operate to spin
I have a Roper washing machine model # RA S7133KQ1. On all cyle it does not spin or drain but it does agitate. I checked the capacitor, timer and water pump. All is good there. What could be the problem? There is no agitate or spin solenoids in this unit. Could it be the motor coupling for the direct drive washer? Am I missing something else that could be wrong with it? Waiting to hear from the expert.
May 08, 2010 | Roper RAS6233KQ Top Load Washer
My roper frig it has water inside under the vegie
clogged freezer drain in freezer. remove cover and work some hot water in and out of the drain with a turkey baster until water runs thru and then poutr more water thru drain until all ice is washed thru. good luck.
Jan 20, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper washing machine hot water won't shut off
An obstruction in the hot water-inlet valve may mean that it's no longer able to shut off and should be replaced. Good luck !
Sep 11, 2007 | Washing Machines
Roper RAX4232KQ Top Load Washer Logo
113 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
